Setting Cart Content In PHP Variable (ARRAY)
Thread begun 8/03/2012 10:30 am by ZP | Last modified 8/06/2012 11:09 am by Jason Byrnes | 2206 views | 3 replies |
ZP
Hi Support,
Im trying to set the cart contents in a PHP variable so I can email it to the customer.
Setting up the normal array is fine but I need to use the repeat cart function
i.e.
$email_contents=
while (!$eCart1->EOF()){
$eCart1->DisplayInfo("Quantity") "X" htmlentities($eCart1->DisplayInfo("Name"));
$eCart1->MoveNext();
$eCart1->MoveFirst();
Any suggestions please....
why not just add the Cart display to the email body and select to use an Email freindly display type?
ZP
Hello,
The email code / system I am using uses a special HTML mark up.
It can use:
SERVER
REQUEST
COOKIE
SESSION
AND POST however I cannot use POST for this page.
So I am looking to put the content is some REQUEST variable but I need the cart looper with the code.
Thanks in advance.
inside the loop, assign the cart values to your variable. for example:
$myVariable = "";
$myVariable = $myVariable . "Quantity: " . $eCart1->DisplayInfo("Quantity") . " Name: " . htmlentities($eCart1->DisplayInfo("Name")) . " ";
