DataBridge errors out
Thread begun 8/02/2012 8:26 pm by rjbayerl157031 | Last modified 8/08/2012 11:17 am by Jason Byrnes | 5301 views | 12 replies |
rjbayerl157031
I'm trying to run Database Pages and keep getting an error saying
"Error in makePreview:
TypeError: pElm has not properties"
I can only click OK and get this error message
"Error in uiInitialize:
TypeError:
wa.user_interface.preview_array[0].preview_object.cleanUpOld is not a function
Again I can only click OK
I get a blank box titled "DataAssist: Create Pages". I have to click the X box in the upper right corner which causes the box to go away.
I uninstalled DataBridge and reinstalled it. Still the same error.
Since the last time it worked I installed eCart (just today). I'm going to install it and see if that helps.
I also have Design Extender and CSS Sculptor installed.
Dick Bayerl
rjbayerl157031
DataBase Pages erros
Uninstalled eCart. Still the same error when running database pages.
Dick
Morgan
Hi, have you tryed uninstall DE, DB and deleted the WinFileCache.dat too? (If you using Windows)
I see you say you have "I also have Design Extender and CSS Sculptor installed."
CSS Sculptor is included in Design Extender so no need to have the singel CSS Sculptor-extention installed.
If the case is that you have the CSS Sculptor installed that maybe cause the problem for you.
Try reinstall the 3 packs, Cart -> DE -> DB
Regards Morgan
rjbayerl157031
Database errors out
Thanks, Morgan.
Uninstalled and reinstalled.
Still can't run database pages. Now it gives this error:
While executing onLoad in WADA_Main.htm, the following JavaScript error(s) occurred:
In file WADA_Main":
initializeUI is not defined
Ran CSS menu writer from DE and it worked.
And other DA extensions work (at least the couple I tried). Just Database Pages won't work.
Dick
Delete the Dreamweaver Cache file from the users configuration folder:
common_installation_issues.php
rjbayerl157031
Database pages error
Did the delete cache and database pages still fails to run. Same error.
Dick
what other extensions are installed?
Make sure you only have eCart, data Bridge and design Extender installed. Also make sure that eCart was not the last extension you installed.
rjbayerl157031
Database pages still error
Jason
Ok, I have just eCart, DE and DB installed in that order. When I ran the Database Pages it went thru the serial number bit and then errors out with that same "WA_getColumnList is not defined" error.
A question: When you say make sure I only have the above three installed, does that mean no other extensions from other sources or only those three WA packages?
I'm wanting to go thru the fine tutorial you guys put together for doing data base sites and am stymied because step one is to run the Database Pages. I have run it before. Not sure when it went wrong. That was within a couple weeks ago.
I'm thinking I'm going to move my tutorial activities to my MacBook to see if I can get some of it done there. But I'm getting close to wanting to do a few data base projects live and want to do them with my PC.
Dick
rjbayerl157031
Database Pages error
Jason,
I want to tell you that I did not run eCart or any of the DE extensions before running DA. Could that be a problem.
Thanks again.
Dick
