undefined function microtime_float() error on confirm page
Thread begun 8/02/2012 4:00 pm by rgolab68503 | Last modified 8/14/2012 8:42 am by Jason Byrnes | 10671 views | 11 replies |
rgolab68503
Hi Jason,
This is kind of a continuation to my last thread but with different issues.
Ray went into my computer and for some reason when he tried to add teh checkout functions he did not come up with the same errors we came up with. This in a way is a good thing. Most the pages are work up to the confirm page. I added the error reporting code to the top of the page and when I try "Submit the order" I get this error.
Fatal error: Call to undefined function microtime_float() in /var/www/html/toyo_support_site/support/Display/confirm.php on line 110
I attached the confirm page and the checkout page just in case that is the route of the problem.
Any ideas?
the universal Email code bloack that is curently at lines 75 - 163:
if (!isset($_SESSION))session_start();
if (((
$_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST)))     {
//WA Universal Email object="mail"
set_time_limit(0);
$EmailRef "waue_confirm_4";
$BurstSize 1;
$BurstTime 200;
$WaitTime 1;
$GoToPage "";
$RecipArray = array();
$StartBurst time();
$LoopCount 0;
$TotalEmails 0;
$RecipIndex 0;
// build up recipients array
$CurIndex sizeof($RecipArray);
$RecipArray[$CurIndex] = array();
$RecipArray[$CurIndex ][] = "".((isset($_SESSION["eCartCheckoutForm_firstname"]))?$_SESSION["eCartCheckoutForm_firstname"]:"")  ." ".((isset($_SESSION["eCartCheckoutForm_lastname"]))?$_SESSION["eCartCheckoutForm_lastname"]:"")  ."|WA|".((isset($_SESSION["eCartCheckoutForm_email"]))?$_SESSION["eCartCheckoutForm_email"]:"")  ."";
$TotalEmails += sizeof($RecipArray[$CurIndex]);
$RealWait = ($WaitTime<0.25)?0.25:($WaitTime+0.1);
$TimeTracker = Array();
$TotalBursts floor($TotalEmails/$BurstSize);
$AfterBursts $TotalEmails $BurstSize;
$TimeRemaining = ($TotalBursts $BurstTime) + ($AfterBursts*$RealWait);
  if (
$TimeRemaining < ($TotalEmails*$RealWait) )  {
$TimeRemaining $TotalEmails*$RealWait;
$_SESSION[$EmailRef."_Total"] = $TotalEmails;
$_SESSION[$EmailRef."_Index"] = 0;
$_SESSION[$EmailRef."_Remaining"] = $TimeRemaining;
  while (
$RecipIndex sizeof($RecipArray))  {
$EnteredValue is_string($RecipArray[$RecipIndex][0]);
$CurIndex 0;
    while ((
$EnteredValue && $CurIndex sizeof($RecipArray[$RecipIndex])) || (!$EnteredValue && $RecipArray[$RecipIndex][0])) {
$starttime microtime_float();
      if (
$EnteredValue)  {
$RecipientEmail $RecipArray[$RecipIndex][$CurIndex];
      }  else  {
$RecipientEmail $RecipArray[$RecipIndex][0][$RecipArray[$RecipIndex][2]];
$EmailsRemaining = ($TotalEmails$LoopCount);
$BurstsRemaining ceil(($EmailsRemaining-$AfterBursts)/$BurstSize);
$IntoBurst = ($EmailsRemaining-$AfterBursts) % $BurstSize;
      if (
$AfterBursts<$EmailsRemaining$IntoBurst 0;
$TimeRemaining = ($BurstsRemaining $BurstTime 60) + ((($AfterBursts<$EmailsRemaining)?$AfterBursts:$EmailsRemaining)*$RealWait) - (($AfterBursts>$EmailsRemaining)?0:($IntoBurst*$RealWait));
      if (
$TimeRemaining < ($EmailsRemaining*$RealWait) )  {
$TimeRemaining $EmailsRemaining*$RealWait;
$CurIndex ++;
$LoopCount ++;
session_commit();
session_start();
$_SESSION[$EmailRef."_Index"] = $LoopCount;
$_SESSION[$EmailRef."_Remaining"] = round($TimeRemaining);
session_commit();
wa_sleep($WaitTime);
      include(
"../../webassist/email/waue_confirm_4.php");
$endtime microtime_float();
$TimeTracker[] =$endtime $starttime;
$RealWait array_sum($TimeTracker)/sizeof($TimeTracker);
      if (
$LoopCount $BurstSize == && $CurIndex sizeof($RecipArray[$RecipIndex]))  {
$TimePassed = (time() - $StartBurst);
        if (
$TimePassed < ($BurstTime*60))  {
$WaitBurst = ($BurstTime*60) -$TimePassed;
wa_sleep($WaitBurst);
        else  {
$TimeRemaining = ($TotalEmails$LoopCount)*$RealWait;
$StartBurst time();
      if (!
$EnteredValue)  {
$RecipArray[$RecipIndex][0] =  mysql_fetch_assoc($RecipArray[$RecipIndex][1]);
$RecipIndex ++;
$_SESSION[$EmailRef."_Total"] = 0;
$_SESSION[$EmailRef."_Remaining"] = 0;
session_commit();
session_start();
  if (
function_exists("rel2abs")) $GoToPage $GoToPage?rel2abs($GoToPage,dirname(__FILE__)):"";
  if (
$GoToPage!="")     {
header("Location: ".$GoToPage);
needs to be moved so it comes after the Store Order details code block that ends at line 41 in the confirm page.
rgolab68503
Hey jason,
A little confused. Line 41 when I look at it in Dreamweaver falls right in the middle of this recordset code block.
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
THIS IS WHERE LINE 41 IS ---- case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$pass_word_rsUSERNAME = "-1";
if (isset($_SESSION['pass_word'])) {
$pass_word_rsUSERNAME = $_SESSION['pass_word'];
$user_name_rsUSERNAME = "-1";
if (isset($_SESSION['user_name'])) {
$user_name_rsUSERNAME = $_SESSION['user_name'];
mysql_select_db($database_toyosupport, $toyosupport);
$query_rsUSERNAME = sprintf("SELECT * FROM entry WHERE Password = %s AND Name = %s", GetSQLValueString($pass_word_rsUSERNAME, "text"),GetSQLValueString($user_name_rsUSERNAME, "text"));
$rsUSERNAME = mysql_query($query_rsUSERNAME, $toyosupport) or die(mysql_error());
$row_rsUSERNAME = mysql_fetch_assoc($rsUSERNAME);
$totalRows_rsUSERNAME = mysql_num_rows($rsUSERNAME);
$query_rsPROVINCE = "SELECT * FROM provinces ORDER BY ID ASC";
$rsPROVINCE = mysql_query($query_rsPROVINCE, $toyosupport) or die(mysql_error());
$row_rsPROVINCE = mysql_fetch_assoc($rsPROVINCE);
$totalRows_rsPROVINCE = mysql_num_rows($rsPROVINCE);
Could you confirm where is should be moved to.
my apologies, i meant to type 411.
lines 359 - 411 are the code for the store order details:
// WA eCart Store Cart Details in Db
if (($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST)) // Trigger
$WA_connection $t0y0t1r3s;
$WA_table "orderdetails";
$WA_redirectURL "checkout_success.php";
$WA_indexField "DetailOrderID";
$WA_fieldNamesStr "DetailOrderID|DetailProductID|DetailName|DetailPrice|DetailQuantity";
$WA_fieldValuesStr WA_eCDB_ConvertNumber("".((isset($_SESSION["Displays_OrderID"]))?$_SESSION["Displays_OrderID"]:"")  ."") . "|" WA_eCDB_ConvertNumber("".$Displays->DisplayInfo("ID")  ."") . "|" "".$Displays->DisplayInfo("Name")  ."" "|" WA_eCDB_ConvertNumber("".$Displays->DisplayInfo("Price")  ."") . "|" WA_eCDB_ConvertNumber("".$Displays->DisplayInfo("Quantity")  ."");
$WA_columnTypesStr "none,none,NULL|none,none,NULL|',none,''|none,none,NULL|none,none,NULL";
$WA_sql "";
mysql_select_db($database_t0y0t1r3s$WA_connection);
$indexFieldIndex = -1;
$WA_fieldValues explode("|"$WA_fieldValuesStr);
  if (!
session_id()) session_start();
  if (
$WA_redirectURL != "" && isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] !== "" && sizeof($_POST) > 0) {
$WA_redirectURL .= ((strpos('?'$WA_redirectURL) === false)?"?":"&").$_SERVER["QUERY_STRING"];
$WA_fieldNames explode("|"$WA_fieldNamesStr);
$WA_columns explode("|"$WA_columnTypesStr);
  for (
$i 0$i sizeof($WA_fieldNames); $i++)
    if (
$WA_indexField  == $WA_fieldNames[$i])
$indexFieldIndex $i;
      break;
$deleteFieldValue $WA_fieldValues[$indexFieldIndex];
  if (isset(
$deleteFieldValue) && $deleteFieldValue != "")
$deleteParamsObj WA_generateInsertParams(array($WA_indexField), array($WA_columns[$indexFieldIndex]), array($deleteFieldValue), -1);
$WA_sql "Delete from " $WA_table " where " $WA_indexField " = " $deleteParamsObj->WA_dbValues;
$WA_editCmd mysql_query($WA_sql$WA_connection) or die(mysql_error());
$WA_okToDelete false;
$Displays->MoveFirst();
  while (!
$Displays->EOF())
$insertParamsObj WA_generateInsertParams($WA_fieldNames$WA_columns$WA_fieldValues, -1);
$WA_sql "insert into ".$WA_table." (".$insertParamsObj->WA_tableValues.") values (".$insertParamsObj->WA_dbValues.")";
$Displays->MoveNext();
  if (
$WA_redirectURL != "")  {
header("Location: ".$WA_redirectURL); exit;
the UE code block needs to be after the details are stored.
rgolab68503
No worries, I thought that is was you meant so i tried it that way before. I have made the changes but I think it got worse.
These are the errors that come up now.
Notice: Undefined variable: t0y0t1r3s in /var/www/html/toyo_support_site/support/Display/confirm.php on line 221
Notice: Undefined variable: database_t0y0t1r3s in /var/www/html/toyo_support_site/support/Display/confirm.php on line 234
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /var/www/html/toyo_support_site/support/Display/confirm.php on line 236
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /var/www/html/toyo_support_site/support/Display/confirm.php on line 270
Now i did some changes to the email as well and am wondering if this has caused the erros. Basically in the version before it was supposed to pull a sales reps email. I have now set up a recordset and am pulling it that way. I proved that the email is comming in OK by plaing it on the page (see Error2_aug3.jpg). I attached the new confirm.php as it sits now as well as the checkout.php page.
It is all getting to the confirm page OK but once you hit the "submit order" button then the errors happen and it stays on the confirm page.
rgolab68503
OK, i got a little further. For some reason it dumped the database connection to t0y0t1r3s:
<?php require_once('../../Connections/t0y0t1r3s.php'); ?>
Hoperfully the email part is working now.
rgolab68503
No Mail
OK I am getting to the checkout stage but the mail is not working now.
Attached are the most current files.
are you testing locally or remotely?
make sure you are testing remotely, in most cases the email wont be able to work testing locally unless you have installed an STP server.
In the Universal Email behavior, how have you set the SMTP server settings?
Who is your host?
rgolab68503
hi Jason,
Yes all the tests are on a remote server. Just to be clear as well in case it matters but I have two carts so far working off of the same server. I did a test to make sure the other cart was working and it is (See attach cart_examp_Aug3.jpg).
Mail setup is identical for both: See Cart_emailsetup_Aug3.jpg
Only diference on this page is the CC field which has the recipient getting the information from a database.
I will try removing this option to see if it clears things up and get back to you.
i see the problem.
The store cart details behavior is redirecting to the success page before the email is being sent.
change line 285:
$WA_redirectURL = "checkout_success.php";
$WA_redirectURL = "";
then change line 343:
$GoToPage = "";
$GoToPage = "checkout_success.php";
