Quick question about order of PHP code at start of page
Thread begun 8/01/2012 1:53 pm by iainmacdonald331081 | Last modified 8/02/2012 12:05 pm by iainmacdonald331081 | 1936 views | 2 replies |
iainmacdonald331081
I have DB Update page that is just being used to add images and a PDF to a record just created on a previous page. The set up is a bit convoluted, but this page is the third of a sequence.
In addition to the DB code to update the record and upload the files, there is some code which inserts some keywords into a related table, using the code below:
*insert Lodge Activities into the LodgeActivities table
//sql insert string
$sql = "INSERT INTO ItineraryActivities (ItineraryID, ActivityID) VALUES ";
$ck = $_GET['ckbox'];
//loops though the profiles adding the insert string each profile row
foreach ($ck As $GetIndex => $GetValue){
if ($GetValue=='on'){
$sql .= "('{$_GET['ItineraryID']}', '$GetIndex'), ";
//trims the end ,
$sql = rtrim($sql," ,") ;
//inserts data
mysql_select_db($database_connSafari, $connSafari); mysql_query($sql); echo mysql_error();
This code appears after the DB Update / Upload code, ie immediately before the <DOCTYPE> declaration.
So when the page first loads, it ignores the DB Update / Upload code, and executes the code above, correctly inserting the keywords.
However, when the form is submitted, and executes the DB Update / Upload code, its also executing the code above a again, and creating duplicate records.
Should that happen, or should that part not be executed on form submission, because it would only get as far as the redirect in the DB Update / Upload code before it?
Hope that makes sense - I've attached the page for reference.
the redirect in the update does not specify a page, only a folder?
the page you sent is an index page, but there is no indication of where the page resides in your site.
Is it the index page in the itinerary_added/ folder that the update is redirecting to? if so, that explains why the insert is happening twice.
I would make sure that the redirect on the up date is pointing to another page.
also, in some server configurations, when a header function call is used to redirect the page, it will execute the rest of the code on the page before the redirect is executed.
to prevent this, edit:
header("Location: ".$WA_redirectURL);
exit;
iainmacdonald331081
Thanks Jason - the redirects are all to default index pages within the specified folder, which were all pointing to the right place. All the pages are in their own folder, just to lose the file extensions in the URLs. (For example (index.php) instead of mypage.php
I added the
exit;
and that has resolved the issue.
