Image Sizer Redux: using with dynamic image loop
Thread begun 8/01/2012 5:52 am by msummers194171 | Last modified 8/01/2012 1:10 pm by Jason Byrnes | 5231 views | 8 replies |
msummers194171
I am building a page with a lightbox-type display of images. These images are being loaded dynamically from an array (created from a recordset), allowing new images to be added or exitings ones to be edited/deleted by the client. The relevant code for the loop that places these images on the page is -
<?php foreach ($galleryRecords as $galleryRecord) { ?>
<li><a href="_img/gallery/<?php echo $galleryRecord['filename']; ?>" class="p7lsm_type_img"><img src="_img/gallery/<?php echo $galleryRecord['filename']; ?>" alt="<?php echo $galleryRecord['alt']; ?>" height="240"></a></li>
<?php } ?>
Note that each image is within a list element.
To use Image Resizer with this arrangement, would I just surround this loop with the appropriate resizer markup (taken from a dummy page)? For example, place this BEFORE the start of the loop -
if(TRUE){ // Begin Cached Resized Image: ImageCacheInstance_1343773049107
ob_start();
and this after the end of it?
echo(getCachedResizedImageHTML(ob_get_clean(), "_img/scratch/New folder", "proportion", "", false));
} // End Cached Resized Image: ImageCacheInstance_1343773049107
(of course, I'd place the include at the top of the page)
theres no need to copy code.
You only need to select the image tag in the tag selector, then go to WebAssist -> Image resizer to apply image resizer to the page.
msummers194171
So all the code for the Resizer, being within the loop, would be repeated for each image? OK - will try that.
msummers194171
Jason - doesn't seem to be working. I can see that the cached images have been created and are located in the designated cache folder, but the src attribute is still pointing to the original (unresized) images.
My code now looks like this -
if(TRUE){ // Begin Cached Resized Image: ImageCacheInstance_1343838442669
ob_start();
echo(getCachedResizedImageHTML(ob_get_clean(), "_img/gallery/cache", "proportion", "", false));
} // End Cached Resized Image: ImageCacheInstance_1343838442669
</a></li>
<?php } ?>
can you send a link where i can see the problem please.
msummers194171
test_solutions-panel-fabrication2.php
The link to trigger the lightshow is at the bottom of the page -
Click to see more panel images
msummers194171
OK - I believe that the problem may be due to the lightshow I am using. I can actually see the resizer code on the page but for some reason that is not being picked up by the lightshow scripting. Standby....
msummers194171
Yes, that's definitely the problem. Dang. This is not going to work at all since the image tag is only used as a thumbnail while the link to the actual full-sized image (i.e., the one I'd really need to be resized) is taken from the href of the link that contains the image.
Hmmm....
Yeah, the gallery you are using wont work with Image Resizer because like you say, the full size image is taken from the a href.
Most JQuery and moo tools galleries don't use an a tag and would work, Power Gallery 2 actually uses image resizer to give you control of the image sizes, both thumbnail and large images.
in power gallery 2, you go to the gallery editor and set the size and cropping pattern to use for the thumbs and large images.
