Security not working
Thread begun 7/31/2012 3:09 pm by Eric Goodman | Last modified 8/02/2012 6:58 am by Jason Byrnes | 4434 views | 13 replies |
Eric Goodman
Regarding ticket 144873
I was able to do the entire install, layer into my templates and uploaded everything.
It previews ok but when I try to register I get:
Warning: Cannot modify header information - headers already sent by (output started at /home/beeritu/public_html/registration.php:9) in /home/beeritu/public_html/webassist/form_validations/wavt_scripts_php.php on line 84
Don't know if the whole registration function, login or logout works, can't get that far...
the headers already sent error is caused by output on the page between closing php tags "?>" and opening php tags "<?php".
The output can be a blank space, blank line, text or html.
The error is reporting the output around line 9 of the registration page in this section of the message:
see the following thread for more details on the error and troubleshooting it:
showthread.php?t=19285
Eric Goodman
Error
Around line 9 is still just the head tag info. I don't see anything off.
Here is the info in my head tags:
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
<title>beeritual_advisor_registration</title>
<link href="main.css" rel="stylesheet">
<style type="text/css">
body {
background-image: url(images/beer_background.jpg);
background-repeat: repeat;
</style>
<!-- Start WOWSlider.com HEAD section -->
<link rel="stylesheet" type="text/css" href="engine1/style.css" />
<script type="text/javascript" src="engine1/jquery.js"></script>
<!-- End WOWSlider.com HEAD section -->
function MM_preloadImages() { //v3.0
var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
if (a[i].indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a[i];}}
</script>
</head>
i would need a copy of the registration.php page in order to see the php code and troubleshoot.
what you have posted look like browser source code, not the php code from the registration page.
Eric Goodman
Registration Page
Do you have an email I can forward it to? Too much text to post here.
compress it to a zip archive and attach the zip file.
Eric Goodman
Here is the php for the Registration....
the php code at line 50 - 118:
<?php require_once("webassist/security_assist/wa_cryptencryption.php"); ?>
require_once('Connections/beeritual.php'); ?>
require_once("webassist/form_validations/wavt_scripts_php.php"); ?>
require_once("webassist/form_validations/wavt_validatedform_php.php"); ?>
require_once( "webassist/security_assist/helper_php.php" ); ?>
require_once("webassist/database_management/wa_appbuilder_php.php"); ?>
if (isset($_POST["Registration_submit"]))  {
$WAFV_Redirect "".(htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES))  ."?invalid=true";
$_SESSION['WAVT_registration_Errors'] = "";
  if (
$WAFV_Redirect == "")  {
$WAFV_Redirect $_SERVER["PHP_SELF"];
$WAFV_Errors "";
$WAFV_Errors .= WAValidateRQ((isset($_POST["Registration_group_Email"])?$_POST["Registration_group_Email"]:"") . "",true,1);
$WAFV_Errors .= WAValidateUnique(("beeritual"),$beeritual,$database_beeritual,"pcms2_users","UserID","none,none,NULL","".((isset($_SESSION["SecurityAssist_UserID"]))?$_SESSION["SecurityAssist_UserID"]:"0")  ."","UserEmail","',none,''","".((isset($_POST["Registration_group_Email"]))?$_POST["Registration_group_Email"]:"")  ."",true,2);
$WAFV_Errors .= WAValidateRQ((isset($_POST["Registration_group_Password"])?$_POST["Registration_group_Password"]:"") . "",true,3);
$WAFV_Errors .= WAValidateEL((isset($_POST["Registration_group_Password"])?$_POST["Registration_group_Password"]:"") . "",6,500,true,4);
$WAFV_Errors .= WAValidateLE((isset($_POST["Registration_group_Confirm"])?$_POST["Registration_group_Confirm"]:"") . "",(isset($_POST["Registration_group_Confirm"])?$_POST["Registration_group_Confirm"]:"") . "",true,5);
$WAFV_Errors .= WAValidateRQ((isset($_POST["Registration_group_First_Name"])?$_POST["Registration_group_First_Name"]:"") . "",true,6);
$WAFV_Errors .= WAValidateRQ((isset($_POST["Registration_group_Last_Name"])?$_POST["Registration_group_Last_Name"]:"") . "",true,7);
$WAFV_Errors .= WAValidateRQ((isset($_POST["Registration_group_Address"])?$_POST["Registration_group_Address"]:"") . "",true,8);
$WAFV_Errors .= WAValidateRQ((isset($_POST["Registration_group_City"])?$_POST["Registration_group_City"]:"") . "",true,9);
$WAFV_Errors .= WAValidateRQ((isset($_POST["Registration_group_State"])?$_POST["Registration_group_State"]:"") . "",true,10);
$WAFV_Errors .= WAValidateRQ((isset($_POST["Registration_group_10_Zip"])?$_POST["Registration_group_10_Zip"]:"") . "",true,11);
$WAFV_Errors .= WAValidateRQ((isset($_POST["Registration_group_1_Phone"])?$_POST["Registration_group_1_Phone"]:"") . "",true,12);
$WAFV_Errors .= WAValidateLE((strtolower(isset($_POST["Security_Code"])?$_POST["Security_Code"]:"")) . "",((isset($_SESSION["captcha_Security_Code"]))?strtolower($_SESSION["captcha_Security_Code"]):"") . "",true,13);
$WAFV_Errors .= WAValidateLE((strtolower(isset($_POST["Security_Answer"])?$_POST["Security_Answer"]:"")) . "",((isset($_SESSION["random_answer"]))?strtolower($_SESSION["random_answer"]):"") . "",true,14);
$WAFV_Errors .= WAValidateRX((isset($_POST["Hidden_Field"])?$_POST["Hidden_Field"]:"") . "","/.* /",false,15);
  if (
$WAFV_Errors != "")  {
PostResult($WAFV_Redirect,$WAFV_Errors,"registration");
// WA DataAssist Insert
if ((isset($_POST["Registration_submit"]) && $_POST["Registration_submit"] != "")) // Trigger
$WA_connection $beeritual;
$WA_table "pcms2_users";
$WA_sessionName "SecurityAssist_UserID";
$WA_redirectURL "login.php?success=1";
  if (
function_exists("rel2abs")) $WA_redirectURL $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString true;
$WA_fieldNamesStr "UserEmail|UserPassword|UserFirstName|UserLastName|UserAddress|UserAddress2|UserCity|UserState|UserZip|UserCountry|UserPhone|UserFax";
$WA_fieldValuesStr "".((isset($_POST["Registration_group_Email"]))?$_POST["Registration_group_Email"]:"")  ."" $WA_AB_Split "".((($_POST["Registration_group_Password"] != ""))?WA_CryptEncryption($_POST["Registration_group_Password"]):$row_SecurityAssistpcms2users["UserPassword"])  ."" $WA_AB_Split "".((isset($_POST["Registration_group_First_Name"]))?$_POST["Registration_group_First_Name"]:"")  ."" $WA_AB_Split "".((isset($_POST["Registration_group_Last_Name"]))?$_POST["Registration_group_Last_Name"]:"")  ."" $WA_AB_Split "".((isset($_POST["Registration_group_Address"]))?$_POST["Registration_group_Address"]:"")  ."" $WA_AB_Split "".((isset($_POST["Registration_group_Address_2"]))?$_POST["Registration_group_Address_2"]:"")  ."" $WA_AB_Split "".((isset($_POST["Registration_group_City"]))?$_POST["Registration_group_City"]:"")  ."" $WA_AB_Split "".((isset($_POST["Registration_group_State"]))?$_POST["Registration_group_State"]:"")  ."" $WA_AB_Split "".((isset($_POST["Registration_group_10_Zip"]))?$_POST["Registration_group_10_Zip"]:"")  ."" $WA_AB_Split "".((isset($_POST["Registration_group_11_Country"]))?$_POST["Registration_group_11_Country"]:"")  ."" $WA_AB_Split "".((isset($_POST["Registration_group_1_Phone"]))?$_POST["Registration_group_1_Phone"]:"")  ."" $WA_AB_Split "".((isset($_POST["Registration_group_1_Fax"]))?$_POST["Registration_group_1_Fax"]:"")  ."";
$WA_columnTypesStr "',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''|',none,''";
$WA_fieldNames explode("|"$WA_fieldNamesStr);
$WA_fieldValues explode($WA_AB_Split$WA_fieldValuesStr);
$WA_columns explode("|"$WA_columnTypesStr);
$WA_connectionDB $database_beeritual;
mysql_select_db($WA_connectionDB$WA_connection);
session_start();
$insertParamsObj WA_AB_generateInsertParams($WA_fieldNames$WA_columns$WA_fieldValues, -1);
$WA_Sql "INSERT INTO `" $WA_table "` (" $insertParamsObj->WA_tableValues ") VALUES (" $insertParamsObj->WA_dbValues ")";
$MM_editCmd mysql_query($WA_Sql$WA_connection) or die(mysql_error());
$_SESSION[$WA_sessionName] = mysql_insert_id($WA_connection);
  if (
$WA_redirectURL != "")  {
$WA_redirectURL str_replace("[Insert_ID]",$_SESSION[$WA_sessionName],$WA_redirectURL);
    if (
$WA_keepQueryString && $WA_redirectURL != "" && isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] !== "" && sizeof($_POST) > 0) {
$WA_redirectURL .= ((strpos($WA_redirectURL'?') === false)?"?":"&").$_SERVER["QUERY_STRING"];
header("Location: ".$WA_redirectURL);
should be at line 1 of the page, this php code needs to come before the HTML code on your page.
In fact this page is very badly formatted altogether.
there is a doctype, <head> and <body section started at lines 1 - 49 and a second doctype, <head> and <body> section started at lines 118 - 135. this is not valid HTML. having the 2 doctype tags in place is probably why the Security assist code was placed incorrectly
Eric Goodman
Security
I moved that code to the beginning as mentioned.
Now it seems as though login isn't going and probably the other stuff as well.
This site was put together pretty simply with div and content. I don't know why the software isn't putting the code in the right spots. Attached are the other files.
all of the pages have the same problem, there are duplicate doctype, head and body tags on your page, this is causing the problems.
are you applying a template to the pages after they are created? or do the pages already exist? It looks like you have pages that already exist that have poorly formatted code. Delete the pages and run the Security Assist wizard again to re create tehm without having the existing pages in place.
to apply your site design after security assist has created them, you should use a template.
