Upload Images Problem
Thread begun 8/04/2009 11:24 am by rharman1306375 | Last modified 9/21/2009 10:44 am by Jason Byrnes | 5775 views | 9 replies |
rharman1306375
Hi
I read all the support threads but am not able to resolve my issue.
I get the error message Please enter a valid file (.gif, .jpg, .jpeg, .png).
I am still testing the store on my PC, running XP and php 5.3
I have set the folder permissions so all of my users have full access.
I have tried various different directories, all with ful permissions, but the product will not load since the images are not being upload.
It seems one persons issue was solved, but the suggestions are not working for me.
It is possible that there is a function being used that has been deprecated in php5.3.
try adding the following at line 1 if the products insert page to see if there is a php error occurring:
error_reporting
(E_ALL);
If any errors are being displayed, please post back the text of the error.
rharman1306375
Hi
I tried the code, but had the same result, without any error code.
What should we try next?
I will need to debug this issue with you.
I have created a technical support ticket, please update the ticket by logging into your support history at;
Paul
Jason,
Please post the results when you have fixed his problem. I'm having the same issue with PS1 and PS2.
In debugging this issue, we came across two problems:
1) Permissions on the image upload folder - The IUSR_<Machine_Name> Account had no permissions set on the upload folder. We set it to full.
2) PHP 5.3 has deprecated the split function, this function is used in the WA_ValidationToolkit/WAVT_Scripts_PHP.php file. We did a find to replace all occurrences of the split function with the explode function. I am attaching a fixed copy of that file to this reply.
Paul:
Let me know if this helps out or not. If not, I will open a ticket for you as well.
Paul
Jason,
I made the changes that you said for the IUSR account, and also replaced the file...I still can't upload pictures. I get the: Please enter a valid file (.gif, .jpg, .jpeg, .png).
This version of PowerStore is 1.
Paul
I have created a support ticket for you so we can investigate this issue. Please update your support ticket by logging into your support history at the following URL:
morc.mzw383871
Powerstore V2 Upload Image issue
I have the same problem. What is the final solution? Please explain it step by step. Thank you.
You also posted this in a another thread, see my reply there:
showthread.php?t=3693&page=2
