Urgent problems with redirects
Thread begun 7/26/2012 2:35 pm by Miguel | Last modified 7/27/2012 7:45 am by Miguel | 7157 views | 16 replies |
Miguel
I made some pages with security assist and another custom for registration using css formbuilder and dataassist, the pages that have inserts or updates like the forgot password or register page after completing filling the form they redirect wrong, i have on the goto page: thankyou.php but when it insert or updates the data wich does it well it sends me to the thankyou.php but without the domain, i have done these pages before but sundenly these last update did something that its not detecting the full path, im on a deadline hope this can be fix asap
Andrew Read
Can you post a copy of one of them and I can take a look at them for you...
I'm guessing that there is an issue with your $WA_RedirectURL value...
Miguel
http://www.deleted.com/registro.php
Its a very long form its happening on the forgot form to but that one would need a registered account first.
another thing i notice if i change for example
$GoToPage = "completado.php";
to
$GoToPage = "http://domaiin.com/completado.php";
when the form is filled it ends up http//domaiin.com/completado.php missing the : after the http
Andrew Read
Can you post the php file, I can't see the code when I view it on the website. :)
Miguel
Originally Said By: Andrew Read
Yea sure sorry there in the zip i added 2 of them so you can see
Andrew Read
OK, you sent me two files... registro.php and olvido.php
Are you having the same problems with both of them?
I'll also ask if you have installed the latest version of Data Bridge [1.0.6] (and Design Extender [1.1.0] if you own it as well?) Also, did you uninstall the previous versions before you installed the new ones, and install them after eCart or any other legacy extensions that are NOT included in DB or DE?
Miguel
Yes have installed latest version of both and also i delete the config folder before installing after deleting the folder i also checked to delete them from the extension manager
Andrew Read
Can you replace line 599 of registro.php with:
die($GoToPage); header("Location: ".$GoToPage);
and report back what is displayed when the form is completed. It should display the $GoToPage variable.
Andrew Read
Also, if you want to figure out where / how the url is being corrupted you can try changing any of the $WA_redirectURL or $GoToPage variables to the location you want to go to.
Start with the first one (line 306), fill out the form and submit it (only that first insert/email will complete.) Do you get where you think you should get to? If so, then remove the URL from that one and move on to the next one.
Once you figure out which one is not working properly you can try to figure out where it is being corrupted between the last working header redirect and the current one using die($variable); in various places to see at which point it gets corrupted. You can move the die() command, save the file and simply hit refresh on your testing server to reload the filled form and try the die in the new place.
Make sense?
Andrew Read
The only bit of code that I see that looks suspect, bur should work, is on line 597:
if (function_exists("rel2abs")) $GoToPage = $GoToPage?rel2abs($GoToPage,dirname(__FILE__)):"";
It is an if conditon without braces around the action " if (conditon) {action;} This is supposed to be kosher, but I would maybe add the braces and see what happens:
if (function_exists("rel2abs")) { $GoToPage = $GoToPage?rel2abs($GoToPage,dirname(__FILE__)):"";}
Grasping at straws though. ;)
