Odd code changes by image resizer in WADA form.
Thread began 7/26/2012 10:43 am by Andrew Read | Last modified 8/01/2012 1:26 am by Andrew Read | 929 views | 5 replies |
Andrew Read
OK, I have a WADA form with a file field in it, generally on the update page I show a thumbnail of the image to the users and let them know that if they leave the file field blank the current file will be kept.
I decided to use image resizer to display the thumbnail this time (I have never used it before) so I am not sure if this is a bug, or me doing something incorrectly.
The code before image resizer is added:
<li class="formItem">
            <div class="formGroup">
                  <div class="lineGroup">
                     <div class="fullColumnGroup">
                          <div class="errorGroup">
<div class="fieldPair">
                       <div class="fieldGroup">
                       <span>
  <input name="fieldPicture" type="file" id="fieldPicture" size="30">
<label for="fieldPicture" class="sublabel" >Picture</label>
<br>
&emsp;&emsp;Current image (leave picture field blank to keep this image): <img  src="../../folder1/folder2/<?php echo $row_WADAtablename['fieldPicture']; ?>" width="100" height="100" alt="<?php echo $row_WADAtablename['fieldModel']; ?> Image"></span>
                       </div>
                       </div>
                          </div>
                     </div>
                  </div>
            </div>
            </li>
The code after image resizer is added:
                           <span>
if(TRUE){ // Begin Cached Resized Image: ImageCacheInstance_1343324518405
ob_start();
                        <br>
&emsp;&emsp;Current image (leave picture field blank to keep this image): <img  src="../../folder1/folder2/<?php echo $row_WADAtablename['fieldPicture']; ?>" width="100" height="100" alt="<?php echo $row_WADAtablename['fieldModel']; ?> Ima<?php
echo(getCachedResizedImageHTML(ob_get_clean(), "../../folder1/folder2/thumbnails""proportion"""false));
// End Cached Resized Image: ImageCacheInstance_1343324518405
?>ge"></span> </div>
                       </div>
                          </div>
                     </div>
                  </div>
            </div>
            </li>
It looks like the resizer is inserted in an odd place and it breaks the span as well.
you should select the image tag in the tag inspector before inserting image resizer.
the code generated should be around the image tag, it looks like you may have had the more than the image tag selected. change the code to:
                           <span>
                        <br>
&emsp;&emsp;Current image (leave picture field blank to keep this image): <?php
ob_start();
<img  src="../../folder1/folder2/<?php echo $row_WADAtablename['fieldPicture']; ?>" width="100" height="100" alt="<?php echo $row_WADAtablename['fieldModel']; ?> Image"><?php
?></span> </div>
                       </div>
                          </div>
                     </div>
                  </div>
            </div>
            </li>
Andrew Read
OK it's a bug... :)
Must be a bug then, as that is exactly what I have tried 3 times, and it always products the same results.
What I am doing:
I am not able to reproduce the bug, so will need to start an incident so ray can look into it.
Andrew Read
Copy that!
Andrew Read
Apparently the "#1"s caused by the issue within the dropdown menu creater in the wizard (see thread) was causing the issue with Image Resizer.
Delete the "#1"s and the image resizer works fine.
Problem will be solved by fixing other issue in the next update.
Thanks again Ray and Jason!
