Dreamweaver will not open any Data Bridge Extension
Hi
Did fresh install of Mountain Lion. all my old extentions work and register on CS6, but Data Bridge gives javascript error. See attached image
Help needed
Hi
Help needed
The usual answer is to (a) try deleting the cache file in the configuration folder (not sure where it resides on Lion); or (b) to delete the extensions and reinstall them. Make sure eCart or any other OLDER extensions (if you own them) are the FIRST extension to be installed, DataBridge and DesignExtender should be installed LAST (in any order.)
Do not install extensions that you own that have been replaced by Data Bridge or Design Extender either.
Fixed, thank you. Just uninstalled Data Bridge, Cleaned cache and reinstalled. I forgot it should be the last one I should reinstall.
Much appreciated
