Upload File: Finish button doesn't work
Thread begun 7/26/2012 12:54 am by CJ | Last modified 8/22/2012 11:56 am by sandy170299 | 5595 views | 9 replies |
CJ
I've just updated to databridge 1.06 (windows 7 64 bit, dreamweaver cs6).
I want to make a change to my file upload (I want to set a default file on my update page).
But now the "Finish button" doesn't work anymore. (see image)
Is there a fix?
Regards,
CJ.
Steve E
I have the same problem, just updated to the latest version
here is an updated copy of the Configuration/shared/webassist/library/WA_SBEngine.js file to correct the problem.
if you need help finding the users configuration folder, see the common installation issues page:
common_installation_issues.php
CJ
Thank you Jason,
I updated the WA_SBEngine.js file and it works fine now.
Cheers
Steve E
Thanks Jason, that fixed it.
Miguel
Im having the same issue but with dataassist that file didnt fix it for the update single record when clicking ok it does nothing
I am not able to reproduce this issue
sandy170299
Jason, i'm having the same problem. Clicking the Finish button on the upload wizard does nothing. However, I am unable to find the WA_SBEngine.js file on my c:/ drive - anywhere. I am running windows 7. Do you know where this file is located? Thank you.
sandy170299
Jason - I found it and it works. Thank you.
