Possible Bug? Multiple dropdown menus created by DA leave <?php opening in place.
Thread begun 7/25/2012 12:58 pm by Andrew Read | Last modified 8/05/2012 7:08 pm by Andrew Read | 5708 views | 10 replies |
Andrew Read
First off, let me say that I truly appreciate the quick and timely support from all of the folks at WebAssist and for the quick fixes and updates.
That said, let's move on to this new issue:
Using WADA to create a List and form with two dropdown menus (not dependent!) I receive the following error on the Insert and Update pages:
  Parse error: syntax error, unexpected '<' in ...
Upon further investigation into the insert page at the specified line I find the following code:
mysql_free_result
($WADAseason);
php
mysql_free_result
($WADAday);
?>?>l>
In the Update page I find the following code:
mysql_free_result
($WADAws_hours);
php
mysql_free_result
($WADAseason);
php
mysql_free_result
($WADAday);
?>?>?>l>
Anyway, that should be easy enough to figure out a solution to, just a few extranious parser open and closes left over.
Andrew Read
Another bug, noticed before but not reported
I noticed this before but forgot to report it:
<option value="<?php echo $row_WADAseason['SCRUBID']?>"<?php if (!(strcmp($row_WADAseason['SCRUBID'], (isset($_GET["invalid"])?ValidatedField("hourUpd","SCRUB"):"".$row_WADAws_SCRUB2["SCRUB"]."")))) {"selected=\"selected\"";} ?>><?php echo $row_WADAseason['SCRUB3']?></option>
This is missing the echo before the {"selected=\"selected\"";}
<option value="<?php echo $row_WADAseason['SCRUBID']?>"<?php  if (!(strcmp($row_WADAseason['SCRUBID'],  (isset($_GET["invalid"])?ValidatedField("hourUpd","SCRUB"):"".$row_WADAws_SCRUB2["SCRUB"].""))))  {echo "selected=\"selected\"";} ?>><?php echo  $row_WADAseason['SCRUB3']?></option>
It has happened every time I have created a dropdown menu via WADA.
Andrew Read
More impact than noticed initally
**NOTE: The code in question is actually being inserted in the middle of the closing html tag:
</script></body>
</h>
mysql_free_result
($WADAws_equip_fs);<?php
mysql_free_result
($WADAefsStatus);<?php
mysql_free_result
($WADAefsClass);<?php
mysql_free_result
($WADAefsEtype);<?php
mysql_free_result
($WADAefsBrand);
?>tml>
I am not able to reproduce this issue, I will start an incident so ray can look into it with you.
Andrew Read
Also...
I will also add in this bit of info:
I am noticing a #1 in all of my dropdown menu code and I'm not sure what is does or where it is coming from, it is just before the "</select>":
<select class="formMenufield_XLarge" name="fieldLabel" id="fieldLabel" onChange="hideServerError('fieldLabel_ServerError');">
<option value="">Choose one...</option>
do {
        <option value="<?php echo $row_WADAtableName['fieldID']?>"<?php if (!(strcmp($row_WADAtableName['fieldID'], (isset($_GET["invalid"])?ValidatedField("equipUpd","fieldLabel"):"".$row_WADAtableName["fieldLabel"]."")))) {echo "selected=\"selected\"";} ?>><?php echo $row_WADAtableName['fieldDesc']?></option>
} while ($row_WADAtableNamemysql_fetch_assoc($WADAtableName));
$rows mysql_num_rows($WADAtableName);
  if(
$rows 0) {
mysql_data_seek($WADAtableName0);
$row_WADAtableNamemysql_fetch_assoc($WADAtableName);
#1</select>
<label for="fieldLabel" class="sublabel" >Brand<span class="requiredIndicator">&nbsp;*</span></label>
please add this to the support incident so that ray can investigate.
Andrew Read
OK, so the update is that the issue has been figured out, and the users can implement the fixes that I used above fairly easily... but it will be fixed in the next release. :)
Hope this helps someone else as well.
L8r.
david390068Beta Tester
Cure
I am experiencing the same thing. If you wouldn't mind, can you share what was done to resolve this?
Andrew Read
It is explained above, to make it more clear:
You will see something like this:
</script></body>
</h>
mysql_free_result
($WADArecordset1);<?php
mysql_free_result
($WADArecordset2);<?php
mysql_free_result
($WADArecordset3);<?php
mysql_free_result
($WADArecordset4);<?php
mysql_free_result
($WADArecordset5);
?>tml>
Simply fix the closing HTML tag, remove all of the extra PHP parser open commands and everything after the last php parser close tag.
</script></body>
</html>
mysql_free_result
($WADArecordset1);
mysql_free_result($WADArecordset2);
mysql_free_result($WADArecordset3);
mysql_free_result($WADArecordset4);
mysql_free_result($WADArecordset5);
And remove all of the #1 from any of the option select menu lists:
#1</select>
</select>
Thanks. I knew that part. But I don't want to have to do that on every page for the site I am building. I was hoping a solution was found in the databridge files to fix it from happening in the future.
