delete pop up
Thread begun 7/25/2012 12:03 pm by randyw2394710 | Last modified 7/26/2012 7:52 am by Jason Byrnes | 6195 views | 1 replies |
randyw2394710
delete pop up
im try to create a delete popup with the line 152 <div class="band" id="gallery-<?php echo $row_gallery['id']; ?>">
i want the <div id="overlay-delete" class="overlay-popup"> line 194 to pop up when the delete button is pressed on line 163 <img class="delete-icon" src="../images/btn-delete-large.png"/> and be able to delete content
In the overlay-delete div, add a form, with a hidden element in it and a submit button
add a onclick event to the image tag that will show the delete overlay, and set the hidden element to the ID of the gallery to delete:
for example:
<img class="delete-icon"  src="../images/btn-delete-large.png" onclick="document.getElementById('delete-id').value=<?php echo $row_gallery['id']; ?>;document.getElementById('overlay-delete').style.display = 'block'"  />
in the delete record behavior, set the ID Value to use the delete-id hidden element.
randyw2394710
for example:
ive tride to do this example, the overlay popup works. but the info is not passed please check the page for me thanks
the delete gallery form
<form action="" method="post" name="delete_gallery" id="delete-id">
is set to use the id delete-id
and so is the hidden element:
<input id="delete-id" type="hidden" value="<?php echo $row_gallery['gallery_id']; ?>" />
the form needs to use a unique ID name.
also search the ID's of other elements on the page and make sure only the hidden element uses the delete-id.
randyw2394710
hi im still having troulbes could you please look at the new ip files
there is no delete record behavior on this page.
you need to add the delete record behavior in order to delete the record.
randyw2394710
i dont want to delete it i want to show info in new div
you said in your initial posting that you wanted to delete it?
I dont recall reading anything about wanting to show something special in the popup, only that you wanted to delete the record...
what info do you want to show in the popup?
randyw2394710
I want to push the delete button near the gallery then have a popup confirmation div appear with those details the popup appears but there is no info
ok, change the hidden element in the pop up div to a text box.
