Can I Create Multiple Update Behaviors with one Trigger?
Thread begun 7/25/2012 10:47 am by jason363662 | Last modified 7/25/2012 10:56 am by Jason Byrnes | 1005 views | 1 replies |
jason363662
I have a page that has 3 forms. Each form will update different tables in my db. I would like to make it so that I can have one "save" button on the page that will trigger all three update behaviors.
I tried setting each update behavior to fire when a single button is pressed, however I am only able to update one of the tables (from the form where the save button resides) - the other tables update as well but get blank values from the forms.
I assume this is because the form values for the other forms don't persist once an update has fired.
So the question is: is this possible? and how do I implement?
Thanks guys.
you would need to have only 1 form on the page that contains all of the elements to be used for populating the three tables.
if you have multiple forms on a page, only the elements in the form with the submit button in it will be posted.
to update 3 tables, you need 1 form and one submit button, but 3 update record behaviors, one for each table.
