eWay XML
Thread begun 7/25/2012 7:01 am by jarrad407561 | Last modified 7/26/2012 9:42 pm by jarrad407561 | 4803 views | 6 replies |
jarrad407561
eWay XML
Hi, I'm trying to adapt my code to use the beagle anti-fraud XML.. Not having any luck so far, and I can't seem to find a way to display the gateway response, or some sort of error message that could help me debug.
Could someone offer some code to print some error debugging info on the checkout-failure page?
Thanks,
JT
To return the Full request and Full response from eWay, open the bindings panel, click the plus button and select eCart -> Checkout -> Local Checkout Response. from the gateway list, select eWay XML.
in the bindings panel, expand the eway binding group and add the Full request and Full response bindings to your page.
Another way to see the errors, is to write the entire contents of the session to the page:
<pre><?php var_dump($_SESSION); ?></pre>
jarrad407561
Thanks Jason.
I got an error message
[ERRORMESSAGE] => Error: XML not formated correctly to eWAY standards. Reason:Whitespace is not allowed at this location.
Error Code:-1072896749(Test CVN Gateway)
I'm guessing the problem is whitespace somewhere in the XML, does this message give any indication of where to look?
I've studied the whole XML request and cannot see anything wrong, and no whitespace that isnt necessary.
jarrad407561
I have found the reason, and this could have been causing intermittent failures for years, it was because an "&" symbol was sent in the XML in the ewayCustomerInvoiceDescription field.
I str_replace'd the "&" symbol for "and".. All fixed.
Glad to hear you found the problem.
The eWAY Team
Rapid API
We're pleased to hear that the issue has been resolved. If you have any more difficulties with the Beagle XML gateway, you might consider using Rapid API instead (a new gateway which has Beagle and Token built-in, as well as keeping your servers free of card data).
Call us if we can be of any assistance!
Kind regards,
The eWAY Team
jarrad407561
Thanks, I got the Beagle working too, just adapted the old XML api to include ip address and country code
