eCart - continue shopping, update cart, checkout etc. not working
Thread begun 7/24/2012 3:50 pm by rgolab68503 | Last modified 7/26/2012 4:11 pm by rgolab68503 | 3654 views | 6 replies |
rgolab68503
Hey there,
I have built a second information cart onto my site simply to show off a few items so our customers will be able to request more information on. (That's teh next step) However since installing Data Bridge I have found it a little different and it's not working as smoothly as it was before.
I have the cart working so that it populates the cart (add to cart buttons) and I can clear the cart or update quantities ... however ...
... if i click on any of the buttons it simply returns to cart.php? as a blank page. If I hit refresh then the changes appear like updated quantity or remove an item. I cannot however get to the checkout pages or to "continue shopping". It all stays on the cart.php page ignoring the redirect.
Any ideas? I have attached my cart.php page for review.
could be a php error causing the redirect to fail.
to turn error reporting on, add the following code at line 1:
error_reporting
(E_ALL);
once we know what the error is, we will be able to troubleshoot the cause.
rgolab68503
Sorry about that. I was going check that and get the info to you but had to rush out. Looks like i am having a few issues here.
Notice: Undefined variable: t0y0t1r3s in /var/www/html/toyo_support_site/support/Display/cart.php on line 393
Notice: Undefined variable: database_t0y0t1r3s in /var/www/html/toyo_support_site/support/Display/cart.php on line 401
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /var/www/html/toyo_support_site/support/Display/cart.php on line 401
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /var/www/html/toyo_support_site/support/Display/cart.php on line 433
your page is missing the t0y0t1r3s connection
change:
<?php require_once('../../Connections/toyosupport.php'); ?>
require_once('../../Connections/t0y0t1r3s.php'); ?>
rgolab68503
OK Totally frustrated now. I tried the changes above and it didn't do what it should have. I was getting basically the same results where it did actually update the pages but on every button it ended up on the Checkout pages. i then questioned the code that is in the cart.php as it doesn't match at all the code in the previous cart I built with Dynamic suite and ecart. The add to db and session variables all seemed to be placed in the cart.php page. See cart_rev.zip then cart_bak.php which is how ecart built the page. I moved around the code to reflect how it was built before. the results are in cart_rev.zip then cart.php. This is how I got it to get me to the checkout page but it would not go to the confirm page.
I then took it one step further and renamed cart.php to Dcart.php and started again. See Dcart_2ndtry.zip.
This is where I am now. The code except for the order which Dreamweaver seems to move around is how it was built. Now if I try to update, or continue shopping or press any of the buttons it takes me to the checkout_success.php page. If i try to edit the buttons I then get the error as provided in the file attached called Erro_Java_july25_2012.jpg. I did try clearing out the .dat file without any luck there.
Any ideas?
rgolab68503
Thanks. I am back in the office Monday. Hopefully you will have some time to look at it then.
