Data Bridge 1.0.6 has been released
Thread begun 7/24/2012 1:30 pm by Jason Byrnes | Last modified 7/26/2012 8:43 am by JamieEff | 2036 views | 5 replies |
Data Bridge 1.0.6 has been released to correct the following issues:
- Corrected an issue that caused an HTML Editor instance on pages containing dynamic lists and/or menus to re-apply in a position that broke HTML tags after editing.
- Corrected an issue that caused the Preview area in Form Builder to not display a preview.
- Corrected an issue that caused password fields with Validation Tooltips for Spry applied to always pass validation.
- Corrected an issue that caused entities in HTML Editor instances to become encoded after a form submission failed server-side validation.
- Removed the dynamic list/menu settings UI from SecurityAssist's Configure Field Settings interface. The interface was added prematurely and will be re-added back once supporting wizard functionality has been implemented.
- Corrected an issue that caused an error to occur after editing and re-applying a non-wizard applied Email Password server behavior.
- Corrected an issue that caused transparency to be lost in images converted from PNG to GIF during file upload.
- Increased the size of the DataAssist Search UI to eliminate vertical and horizontal scrollbars in Dreamweaver CS6.
- Corrected an issue that caused downloads of .doc files to fail on pages containing DataAssist behaviors.
- Corrected an issue that caused pages to appear to be modified in the Dreamweaver workspace after accessing Form Builder and not actually inserting a form.
- Corrected an issue that prevented additional settings (validation, 'Add confirm password field', etc) for Password fields from displaying when configuring field settings in DataAssist's Create Pages Wizard.
- Corrected an issue that caused button CSS for DataAssist created pages to be incorrect when using button preset names containing dashes and other special characters.
- Added the Show Region Server Behavior to WebAssist >Utilities.
Make sure to uninstall the previous version of Data Bridge before installing this update
PatriceWebAssist
Please advise on installation path. If we just upgrade to DB will DE and Ecart be ok? Or do we uninstall DE, Cart, install DB, then do DE, Ecart? I know there was a sequence issue before, so please go into 's'plain it to me lucy' mode ( for those of a certain age who get that reference)
With eCart, Design Extender and data Bridge, the only install sequence to bear in mind is that you don't install eCart last.
we also released an update for Design extender yesterday, so you should uninstall both Design Extender and Data Bridge, then install the newer versions. It doesn't matter if you install Design Extender First, Or Data Bridge first.
PatriceWebAssist
Thank you.
Andrew Read
Great update, thank your for clearing these up in a timely fashion and thank you for the support that you provide on a daily basis.
JamieEff
Originally Said By: Andrew Read
hear hear!
