Unique Database Value
Thread began 7/24/2012 8:40 am by steve287725 | Last modified 7/24/2012 11:25 am by steve287725 | 636 views | 2 replies |
steve287725
Hello there
I have just successfully downloaded and installed Security Assist 2.05 (after uninstalling 2.04) which as you know fixed an error relative to this validation.
Now it seems to work OK - on a match, the redirect works, but the records still gets inserted - any ideas please?
Also to make sure, if I am matching the user email address, but the PK of the database is UserID, should the validation behavior Key column be UserID and the Key value be SecurityAssist_UserID session variable?
Thanks for your help
probably code order, the insert code is probably before the validation code on your page.
"should the validation behavior Key column be UserID and the Key value be SecurityAssist_UserID session variable?"
Yes, the key column should be the User ID column, the key value should use the session created by the login page. This may or may not be named SecurityAssist_UserID, take a look at the login page, go to the server behaviors panel, double click the Authenticate user behavior, and go to thew sessions tab to see the name of the User ID session that is created.
steve287725
Looks good - thanks again for your help
