adding more then one currency
Is there a way to add more then one currency option i.e Uk & US?. so the customer can pick between two currencies?
Ps im using ps3
Ps im using ps3
Power Store 3 does not offer an option to chose currency. In poser store 3, only USD can be used for currency.
Power Storer 4 will allow you to use other currencies, but does not support a customer picked currency, it can only use one currency set by the admin.
