Error in page
Thread began 7/23/2012 9:50 pm by keith298718 | Last modified 7/24/2012 3:46 pm by keith298718 | 750 views | 2 replies |
keith298718
Error in page
I am using data assist included in the latest data bridge to create pages. On the results page I have an error on line 113 see attached for code. The code is as created by the wizard. This error also appears in other pages created by the wizard it is the string jobs that is causing the problem..
snippet
<input id="jdate" name="jdate" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("currentjobsupdate","jdate"):"".(($row_WADAcurrent jobs["jdate"])?date("m/d/Y",strtotime($row_WADAcurrent jobs["jdate"])):"")."")); ?>" class="formTextfield_Medium" tabindex="1" onBlur="hideServerError('jdate_ServerError');">
Thanks for your help
Keith
current jobs_results.zip
This is happening because you are using a space in your table name "current jobs". You should avoid using spaces when naming the table or columns in your database. You should either use the camelCase naming convention (recommended) or use the underscore character in place of the space (not recommended)
keith298718
Fixed
Keith
