Order Id not enterered in Order Details table
Thread begun 8/04/2009 9:03 am by cheryl75100 | Last modified 8/05/2009 9:35 am by Eric Mittman | 1862 views | 1 replies |
cheryl75100
This has actually been an ongoing problem, a year ago about one in 20 orders would not have the order id entered in the orderdetails table.
This month - 4 or 5 orders a day - about half - are not grabbing the order id.
issue - ORDER SUMMARY RECORDS CORRECTLY
ORDER DETAILS MISSING ORDER ID
This breaks the display of receipts
The insert statement references: Session("OrderNumber") the email receipt for those orders also does not have the order number and references the same session variable.
Can someone please help? When the order summary is stored in the database, it does insert the Session.SessionID but isn't it supposed to then send back the OrderNumber?
here is my code:
<%' WA eCart Store Cart Summary in Db
if (NOT WA_eCart_EOF(PV_eCart)) then
WA_connection = MM_wastore_STRING
WA_table = "orders"
WA_redirectURL = ""
WA_indexField = "OrderID"
WA_fieldNamesStr = "OrderReferenceID|OrderUserID|FName|OrderPhone|OrderEmail|OrderGST|OrderTotal|OrderSubTotal"
WA_fieldValuesStr = "" & cStr(Session.SessionID) & "" & "|" & "" & cStr((Rs_user.Fields.Item("buyer_ID").Value)) & "" & "|" & "" & cStr((Rs_user.Fields.Item("buyer_storename").Value)) & "" & "|" & "" & cStr((Rs_user.Fields.Item("buyer_phone").Value)) & "" & "|" & "" & cStr((Rs_user.Fields.Item("buyer_email").Value)) & "" & "|" & "" & cStr(WA_eCart_GetTax(PV_eCart)) & "" & "|" & "" & cStr(WA_eCart_GrandTotal(PV_eCart)) & "" & "|" & "" & cStr(WA_eCart_GetTaxableTotal(PV_eCart)) & ""
WA_columnTypesStr = "',none,''|none,none,NULL|',none,''|',none,''|',none,''|none,none,NULL|none,none,NULL|none,none,NULL"
WA_sessionName = "OrderNumber"
indexFieldIndex = -1
WA_fieldValues = Split(WA_fieldValuesStr,"|")
WA_fieldNames = Split(WA_fieldNamesStr,"|")
WA_columns = Split(WA_columnTypesStr,"|")
set WA_editCmd = Server.CreateObject("ADODB.Command")
updateFieldValue = ""
WA_editCmd.ActiveConnection = WA_connection
if (WA_redirectURL <> "" AND Request.QueryString <> "" AND Request.QueryString.Count > 0) then
if (inStr(WA_redirectURL,"?") > 0) then
WA_redirectURL = WA_redirectURL & "&"
else
WA_redirectURL = WA_redirectURL & "?"
end if
WA_redirectURL = WA_redirectURL & Request.QueryString
end if
for i = 0 to Ubound(WA_fieldNames)
if (WA_indexField = WA_fieldNames(i)) then
indexFieldIndex = i
exit for
end if
next
if (indexFieldIndex >= 0) then updateFieldValue = WA_fieldValues(indexFieldIndex)
if (updateFieldValue = "") then updateFieldValue = cStr(Session(WA_sessionName))
updateColType = "none,none,NULL"
updateColType = WA_columns(indexFieldIndex)
end if
if (updateFieldValue <> "" AND updateFieldValue <> "undefined") then
valueForWhere = WA_generateInsertParams(Array(WA_indexField), Array(updateColType), Array(updateFieldValue), -1)
sqlstr = "select " & WA_indexField & " from " & WA_table & " where " & WA_indexField & " = " & valueForWhere(2) & " order by " & WA_indexField & " DESC"
set WA_eCartRecordset = Server.CreateObject("ADODB.Recordset")
WA_eCartRecordset.ActiveConnection = WA_connection
WA_eCartRecordset.Source = sqlstr
WA_eCartRecordset.CursorType = 0
WA_eCartRecordset.CursorLocation = 2
WA_eCartRecordset.LockType = 1
WA_eCartRecordset.Open()
if (NOT WA_eCartRecordset.EOF) then
updateFieldValue = cStr(WA_eCartRecordset.Fields.Item(WA_indexField).Value)
else
end if
WA_eCartRecordset.Close()
end if
updateParamsObj = WA_generateInsertParams(WA_fieldNames, WA_columns, WA_fieldValues, indexFieldIndex)
WA_editCmd.CommandText = "update " & WA_table & " SET " & updateParamsObj(3) & " where " & WA_indexField & " = " & valueForWhere(2)
WA_editCmd.Execute()
WA_editCmd.ActiveConnection.Close()
else
insertParamsObj = WA_generateInsertParams(WA_fieldNames, WA_columns, WA_fieldValues, -1)
WA_editCmd.CommandText = "insert into " & WA_table & " (" & insertParamsObj(1) & ") values (" & insertParamsObj(2) & ")"
end if
if (indexFieldIndex < 0) then
obj = WA_generateWhereClause(WA_fieldNames, WA_columns, WA_fieldValues, indexFieldIndex)
sqlstr = "select " & WA_indexField & " from " & WA_table & " where " & obj & " order by " & WA_indexField & " DESC"
if (NOT WA_eCartRecordset.EOF) then Session(WA_sessionName) = WA_eCartRecordset.Fields.Item(WA_indexField).Value
else
Session(WA_sessionName) = updateFieldValue
end if
else
Session(WA_sessionName) = WA_fieldValues(indexFieldIndex)
end if
if (WA_redirectURL <> "") then
Response.Redirect(WA_redirectURL)
end if
end if
<%' WA eCart Store Cart Details in Db
WA_table = "orderdetails"
WA_redirectURL = ""
WA_indexField = "DetailOrderID"
WA_fieldNamesStr = "DetailOrderID|DetailProductID|DetailProductName|DetailProductDesc|DetailQuantity|DetailPrice"
WA_fieldValuesStr = "" & cStr( Session("OrderNumber") ) & "" & "|" & "" & cStr(WA_eCart_DisplayInfo(PV_eCart, "ID")) & "" & "|" & "" & cStr(WA_eCart_DisplayInfo(PV_eCart, "Name")) & "" & "|" & "" & cStr(WA_eCart_DisplayInfo(PV_eCart, "Description")) & "" & "|" & "" & cStr(WA_eCart_DisplayInfo(PV_eCart, "Quantity")) & "" & "|" & "" & cStr(WA_eCart_DisplayInfo(PV_eCart, "Price")) & ""
WA_columnTypesStr = "none,none,NULL|',none,''|',none,''|',none,''|none,none,NULL|none,none,NULL"
else
end if
end if
WA_cmdObjString = "ADODB.Command"
set WA_editCmd = Server.CreateObject(WA_cmdObjString)
indexFieldIndex = i
exit for
end if
next
deleteFieldValue = cStr(WA_fieldValues(indexFieldIndex))
if (deleteFieldValue <> "" AND deleteFieldValue <> "undefined") then
deleteParamsObj = WA_generateInsertParams(Array(WA_indexField), Array(WA_columns(indexFieldIndex)), Array(deleteFieldValue), -1)
WA_editCmd.CommandText = "Delete from " & WA_table & " where " & WA_indexField & " = " & deleteParamsObj(2)
end if
set PV_eCart = WA_eCart_MoveFirst(PV_eCart)
while (NOT WA_eCart_EOF(PV_eCart))
set PV_eCart = WA_eCart_MoveNext(PV_eCart)
wend
end if
end if
It seems that the session variable is not getting set sometimes. I'm not sure why it would behave inconsistently like this. I have created a ticket for this issue, please login to WebAssist.com and visit your support history to update the ticket.
