Product Category - Urgent
Thread began 7/22/2012 7:22 am by s_lasry191696 | Last modified 7/23/2012 8:06 am by Jason Byrnes | 673 views | 1 replies |
s_lasry191696
I have imported the eCommerce MySQL database from webassist. I have created a dynamic site along with a database connection (connection test is good). I started creating the insert and update web pages with the dataassist (within Data Bridge). It seems that whether I am using a "Product Catalog" or "Product Administration" application type, many fields are ignored....including the product category field (which is very imprtant for me).
I tried building data pages from scratch and I manage to see the category field, but when I let data assist run to create the pages I get the following messages. I have named the image files in numerical order so that you can see the sequence of these messages.
Please help me on what can be done with this problem?
Hope to hear from you as sson as possible.
Thank you and regards.
Messages.zip
the first error is happening because the page that the wizard is trying to create is already opened in dreamweaver.
It sounds like you are running the Wizard multiple times and creating the same pages each time.
If the pages that the wizard is trying to create already exist in your site, it will cause the issues you are experiencing. either delete the pages that have already been created before running the wizard, o on the Manage Pages tab, change the names of the pages that will be created, so it will create unique pages.
on the manage pages tab, you may need to edit the properties of each page to customize the columns that will be used.
