Alternative Redirect on Login
Thread begun 7/22/2012 12:05 am by canmor51406258 | Last modified 7/24/2012 6:14 am by Jason Byrnes | 3729 views | 4 replies |
canmor51406258
I want to direct new registrants to Insert Data page directly after registration via the login page. At the same time if current users login I want to direct them to Update Data page. Is it possible to have a choice of redirect pages on login?
no, you cant have 2 redirects, but this can be done by setting a column in the users table to indicate whether they have performed the inert or not.
in the users table create a column named regComplete set the default value to 0
On the insert data page, update the regComplete column to 1 when the data is inserted.
On the login page, edit the Security Assist Authenticate user behavior, go to the Session Variables section and click the plus button, select the regComplete column to have it stored in a session on login, make note of the name that is used. also make note of the UserID session variable name.
For the sake of example, I am going to use "SecurityAssist_UserID" and "regComplete" going forward, you will need to make sure to use the correct session names when following the steps I outline
now you will need to create a new access rule, go to WebAssist -> Security Assist -> Manage Site Access -> Access Rules Manager
Set the name to Completed registration.
Create a condition, select the Restrict radio button. For Value, click the lightning bolt icon and select the SecurityAssist_UserID session variable binding. Set the Criteria to "=" and leave the compare to field blank.
Create another condition, select the Allow radio button. For Value, click the lightning bolt icon and select the regComplete session variable binding. Set the Criteria to "=" and set the Compare to field to 1
Now on the Update Data page, add the page access restriction to allow access only if the Completed registration rule passes.
canmor51406258
Many thanks for that.
canmor51406258
I follow the logic of what needs to be changed but cannot see how on login it will automatically redirect to the update page ( once regComplete is set to 1) when the redirect is set to the insert page. Could you please explain how this will happen?
Set the Success redirect to point to the login page.
The logic works like this:
- The regComplete value is stored in a session at login
- if login is successful they are redirected to the User Update page
- On the user update page, you add an access restriction to only allow access if they have completed the insert page, if not, redirect them to the insert page.
