Manage Relational Tables - can't get it to work.
Thread begun 7/20/2012 9:15 am by John Langer | Last modified 7/24/2012 8:49 am by John Langer | 4940 views | 11 replies |
John LangerBeta Tester
Hi, I'm attempting (for the first time) to create a "Manage Relational Table".
I've created Detail, Insert, Search, Update and Results pages using the Data Bridge "DataAssist pages" function.
During the course of this I have set it up to create a list of options (called "Main Category"). This is displayed in list format so that multiple "Main Categories" can be selected.
I have created a main table (called "courses") an Options table (called "coursemaincategory") and a table for the join (called "coursemaincatoptions").
So far I have only attempted to apply this behaveour to the insert page.
With the insert page open, I opened up the Insert Record (course) behaviour and deleted the page redirection.
I then opened up a new Manage Relational Table behaviour.
On the first page I made the trigger "Button: Insert pressed"
Selected the connection and relational table (coursemaincatoptions)
I then set the "Go to" to "courses_detail.php?CourseID=<?php echo $_SESSION['WADA_Insert_course']; ?>" WADA_Insert_course is the session that Dreamweaver/webassist created.
On the next page I set the Foreign Key column to "FKcourseID"
Data type to Numeric
and the key value to "<?php echo $_SESSION['WADA_Insert_course']; ?>"
On the next page The Foreign key column was set to FKmainCatID
Data type to numeric
Options form field to "'FKmainCatID' Multi-select box"
The next page reported:
mainCatOptionsID Numeric
FKcourseID Numeric Automatically bound master key field
FKmainCatID Numeric Automatically bound joined key field
Clicking finish created "Manage Relational Table (coursemaincatoptions)" in the server behaviors panel.
I then tried it out by inserting a record. (This was on my local machine, none of this is on a server yet). The record was inserted into the courses table but the data inserted into the relational table (coursemaincatoptions) was
mainCatOptionsID FKcourseID FKmainCatID
1 1 0
2 2 0
As you can see the numerical values for the FKmainCatID were not entered.
I've spent quite a few hours trying to figure this out and I'm pretty sure I'm doing it correctly but am open to being wrong :-).
I've attached the files as well as SQL dumps of the tables.
Any pointers in the right direction on this would be appreciated.
here is an updated copy of the webassist/database_management/wa_appbuilder_php.php file that should correct the problem. This is an issue that will be fixed in the next update to Data Bridge that should be released soon.
Thanks Jason, that worked.
Brilliant :-)
Spoke too soon
Hi Jason,
When trying to test this a second time it has failed to work (weird!).
Tried several times but all with the same result, just a big fat 0 entered into the column.
I'm attaching the insert file again for your perusal.
did you make changes to the behavior or other changes to a data assist behavior
any time you make a changes using data assist, it will recreate the webassist/database_management/wa_appbuilder_php.php file in your site with the old one.
to prevent that form happening again after putting the updated one in your site, set the file to be read only so it cannot be overwritten.
Yes I did Jason. I'll do that, many thanks.
Yes that did it Jason. I'll make sure I remember that.
What I did was I added a second MRT to the page for a second multi select list. It didn't work and so I deleted it and then found the original didn't work either (this was because, as you said, the wa_appbuilder_php.php file had been overwritten).
I've now successfully inserted two MRT's to the same page using the updated wa_appbuilder_php.php file. Just for the help of others, I deleted the "go to" URL on the first MRT and added it to the second.
Brilliant!! Don't you just love WebAssist :-)
Andrew Read
You can also replace the file in the configuration folder... that way it overwrites with the new file.
Andrew Read
JS error on redirect file choice?
In regards to the MRT, which I am also getting to work now (thanks for the previous posts!) I am getting a JS error when I try to choose the redirect file within the wizard. See image.
FYI - showpost.php?p=84393&postcount=17 contains a tutorial on how to setup a MRT that I made for DataAssist (solo) and it still applies in DataBridge's DataAssist.
Yes Andrew I'm getting that error message as well but, in ignoring it, it doesn't seem to cause any harm i.e. it still works OK.
And thanks for the tip about putting that file in the config folder, I'll try that.
And... Thanks for that tutorial. It was by following that that I got my head around all this MRT stuff. Just the bug in Data Bridge that threw me.
