Project interrupted
Thread begun 7/19/2012 11:36 am by Patrice | Last modified 7/23/2012 11:45 am by Patrice | 7132 views | 21 replies |
PatriceWebAssist
Project interrupted
About 18 months ago, I started a project for a client using eCart. I think eCart has been updated since that start. I had everything done but the client never set up a paypal account so I could finalize. Now, it is ready to go but it's been too long for me to recall where I left off. All is done except for the final step of checking out to paypal. Now that I have a paypal account provided, ie, email and/api, where do I look to finish this. Brain is stale but I don't want have to start from scratch. Any pointers where to enter the email account for the paypal account or if I need to enter an API, where is this done?
Run the checkout wizard to create the checkout pages, in the checkout wizard, you can enter the account details.
PatriceWebAssist
Thanks Jason. I appreciate it.
PatriceWebAssist
I'm trying to fix this ecart. I put the error code on top of the checkout.php page.
Warning: require_once(@@relpath@@Connections/gator.php) [function.require-once]: failed to open stream: No such file or directory in /var/www/html/checkout.php on line 9
Fatal error: require_once() [function.require]: Failed opening required '@@relpath@@Connections/gator.php' (include_path='.:/php/includes:/usr/share/php') in /var/www/html/checkout.php on line 9
This cart was started pre 5 version. I updated. The cart.php page is ok, but the click thru to check out is a blank page.
send a copy of the checkout.php page
PatriceWebAssist
//WA eCart Include
require_once("WA_eCart/cart1_PHP.php");
<?php require_once('@@relpath@@Connections/gator.php'); ?>
<?php require_once('Connections/gator.php'); ?>
$cart1->GetContent();
//WA eCart Include
require_once("@@relpath@@WA_eCart/WA_eCart_Database_PHP.php");
PatriceWebAssist
OK... one minute.
PatriceWebAssist
attached... thanks
change line 9:
and line 6:
require_once("WA_eCart/WA_eCart_Database_PHP.php");
not sure why @@relpath@@ is being added, in the site definiotn, there is a setting for "Create Link relative to", make sure that is set to document and try Deleting the Dreamweaver Cache file from the users configuration folder:
common_installation_issues.php
PatriceWebAssist
Thanks...that corrected that page. :-)
Then confirm was blank so added the error code there too:
Notice: Undefined variable: cart1 in /var/www/html/confirm.php on line 160
Fatal error: Call to a member function IsEmpty() on a non-object in /var/www/html/confirm.php on line 160
attached confirm page
