Create folder after insert
Thread begun 7/19/2012 10:00 am by ddileo415479 | Last modified 7/23/2012 8:36 am by Jason Byrnes | 2093 views | 3 replies |
ddileo415479
I would like to create a folder on the server after an insert record into mysql database. I found the following code in the forum, but have a few questions:
<?php if($_SERVER["REQUEST_METHOD"] == "POST") {
mkdir("/Galleries/Users/".$_SESSION['userid']."", 0700);} ?>
I'd like to set it to two variables:
/Galleries/Users/ ProfileID [session variable]/ Title [form variable]
So it would check to see if profileid exists; if not it would create folder.
Then it would within that folder create one for a form variable Title.
Any thoughts?
you would need to use file_exists() to check if the directory is created, if not crete is using mkdir.
you would need 2 statement the first to check the session directory, then to check the post directory name.
see this thread on webmaster world for details on how to do this:
r19705384-PHP-check-to-see-if-a-folder-exists
ddileo415479
Insertion Point
If I simply use two variables, without the check:
mkdir("/Galleries/Users/".$_SESSION['userid'].""/".$_GET['Title']."", 0700);} ?>
Not sure where I would insert this code so it functions only on the insert by data assist. Also not sure if I called the second variable correctly.
the code can go at line 1.
in the code you provide, $_GET['Title'] should be $_POST['Title']
The reality is that this is custom code that we do not offer support for. if you need assistance in adding this, please sign up for a premiere support appointment.
