Disable delete button for parent records in use
I want to add a bit of simple functionality to my recordset list, which involves checking if each row is used in a relational table, and if it is then the delete button should be disabled.
Adding the recordset code to the while loop is easy as is checking max rows > 0, however how do I disable the fancy new delete buttons? :)
Thanks.
