No buttons on results pages?
Thread begun 7/19/2012 6:38 am by Andrew Read | Last modified 9/06/2012 10:37 am by Rune Brynestad | 5703 views | 11 replies |
Andrew Read
DW CS 5.5, WA DB 1.0.5
Created results, insert and update pages using Standout as a base and a modified button type.
Aside from noticing that the button icons change from black to white whenever I choose the button that I created in the login wizard (I noticed this with the Basic theme) when I finally did finish setting up the pages with the modified Standout - none of the buttons are displaying. See image attached.
Also, any reason that all of the CSS has to be contained within the documents? Why are these pages not referencing an external CSS file so that we can make changes to them wholesale?
And while I'm at it.. when are the cancel buttons goint to be added to the insert and update forms so that I don't have to manually code them on every page? :)
Andrew Read
Button code
<td class="WADAResultsEditButtons" nowrap="nowrap"><input type="button" class="formButton ResultsPageButton MEETZ Buttons UpdateButton" value="" onclick="document.location.href='PAGE.php?ID=<?php echo($row_WADAws_season['seasonID']); ?>
echo(isset($_GET["pageNum_WADAws_season"])?"&pageNum_WADAws_season=".intval($_GET["pageNum_WADAws_season"]):""); ?>';"/><input type="button" class="formButton ResultsPageButton MEETZ Buttons DeleteButton" value="" onclick="document.getElementById('WADADeleteRecordID').value=<?php echo($row_WADAws_season['seasonID']); ?>;document.getElementById('deleteBox').style.display = 'block';document.getElementById('deleteMessage').style.display = 'table';" /></td>
Hmm, i haven't seen that happen before, the values for the buttons are blank:
value=""
The value is used to as the button label:
value="Update"
or
value="Delete"
What are the application settings you used when running the Data Assist pages wizard so I can try to reproduce this.
Andrew Read
I can demonstrate what I did in a session if you want, however my flow was as follows:
1) create user login pages and modify a button type, save as preset.
2) use dataassist wizard to create pages (results, insert and update) using the theme listed above and choosing my custom button type
3) generate the pages.
That what you needed?
Any answers for my other questions? :)
Ok, I'll give that a try to reproduce, thanks.
Yes, I have already responded to your other posts.
Andrew Read
I meant my other questions in the first post on this page. ;)
Ok, I have reproduced the problem, it seams to occur any time the button design used is modified, I have logged this as a bug so It can be corrected in a future update.
As for the other questions, I don't really have an answer, though i have put through feature requests to have these options considered.
Rune Brynestad
Not fixed yet ?
It looks like the "No buttons on results pages" bug is not fixed in the latest version 1.0.8. It occur any time the button design used is modified. When I'm not modifying the button design it works perfect.
Live url here: eiendommer_public_results.php
I'm attaching my page. Can you please tell me how to update the code manually?
Regards
Rune
the css for the buttons is correct:
form.Firmaeiendom_Kundesider input.formButton.Firmaeiendomkundesider.DetailButton {
background-image: url("images/Icons/view_details_white.png");
background-position: center center;
background-repeat: no-repeat;
cursor: pointer;
height: 29px;
width: 29px;
form.Firmaeiendom_Kundesider input.formButton.Firmaeiendomkundesider.UpdateButton {
background-image: url("images/Icons/edit_white.png");
cursor: pointer;
height: 29px;
width: 29px;
form.Firmaeiendom_Kundesider input.formButton.Firmaeiendomkundesider.DeleteButton {
background-image: url("images/Icons/delete_white.png");
cursor: pointer;
height: 29px;
width: 29px;
but it looks like the back ground images:
have not been uploaded to the server so cannot be displayed.
Rune Brynestad
The icons are uploaded to the server. That was the first thing I checked.
Regards
Rune
