Wrong order time stored in database
Thread begun 7/13/2012 4:47 pm by bill3786 | Last modified 7/16/2012 12:07 pm by bill3786 | 2850 views | 6 replies |
bill3786
The order time being stored in the orders table is 12 hours ahead of the actual time. The order date column value in the ecart store order summary behaviour is <?php echo (date('Y-m-d h:i:s')); ?>
How can this be corrected?
CraigRBeta Tester
sounds like the default timezone may not be set.
take a look at these links, may help you out.
php-default-timezone
function.date-default-timezone-set.php
bill3786
Thanks for your reply on this Craig.
Looked at your suggestions and did some more searching on this. The problem only seems to happen for orders placed after noon in the second 12 hour period.
My conclusion is that it looks as though the date format that ecart placed in the confirm page should have been either <?php echo (date('Y-m-d h:i:s a')); ?> for 12 hour format or <?php echo (date('Y-m-d H:i:s')); ?> for 24 hour format and not <?php echo (date('Y-m-d h:i:s')); ?>
<?php echo (date('Y-m-d h:i:s')); ?> is a 12 hour format without any meridiem indication and I think this may be the problem.
Jason, is my assumption correct, dont want try this out yet because site is now live?
The Format would not make orders after 12 noon be recorded for the next day.
It would just make it look like an order placed at 1 am on July 16th and 1pm on July 16th appear to have placed at the same time.
If it is recording an order made at 1pm on July 16th as being placed on the 17th, then it is the time sone used by the server, and not the format being used to store it.
bill3786
Ok, here are a few of examples of test orders placed on the evening of Friday 13/07/2012 and morning of 16/07/2012
Order placed at 8:44pm on 13/7/2012 and recorded in orders table as 2012-07-13 08:44:29
Order placed at 9:35pm on 13/7/2012 and recorded in orders table as 2012-07-13 09:35:19
Order placed at 7:19am on 16/7/2012 and recorded in orders table as 2012-07-16 07:19:48
The last one which was placed in the morning is recorded ok but the other orders placed in the evening are recorded as a morning order.
This contradicts my first post which should have read "12 hours Behind" and not "12 hours ahead".
Does this still suggest the server time zone problem or should the string be 'Y-m-d h:i:s a' and not 'Y-m-d h:i:s'
This means that you want to add AM or PM to the order date using the format:
Y-m-d h:i:s a
or use a 24 hour format:
Y-m-d H:i:s
bill3786
Ok, thanks, I thought that was the solution but wasnt 100% sure.
