uilnitialize Error
Thread begun 7/13/2012 10:25 am by Steve | Last modified 10/11/2013 9:17 am by Jason Byrnes | 5161 views | 11 replies |
Steve
uilnitialize Error
Any ideas on why this is happening when trying to insert a record for the first time in a clean page? If I remove the Form tag the error does not arrise but even after setting a simple binding value then adding the form tag and trying to open the Insert behavior the error is thrown.
Deleted the .dat file with no change in effect.
can you send a copy of the form that is causing the issue?
Steve
File attached!
your form tag an many of the form elements are missing the ID attribute, this is likely causing the error. add an ID attribute to the form tags and element tags, it can be the value as the name.
Steve
Jason,
I think the problem is related to a Protected or conflicting word "length"
Confirmation ~
Works:
<input name="length2" type="text" id="length2" size="30" maxlength="5">
Fails with the error shown
<input name="length" type="text" id="length" size="30" maxlength="5">
I have reported this as a bug in our bugbase to corrected in future update, thanks for reporting the problem.
superpac250441
data assist won't start up
Hi there,
Suddenly may data assist won't start up. See 2 error messages below. Any idea how I can fix it?
What Version of Dreamweaver are you using?
What is your OS?
What Extensions (Including the version numbers) do you have installed?
do these errors happen when starting the data assist wizard? while setting up the data assist wizard? or after clicking finish in the wizard?
have you tried Deleting the Dreamweaver Cache file from the users configuration folder:
superpac250441
DW CS 6
DB114
DE 115
EC 507
The problem occurs when I start DA wizard. It comes up with each error in uploaded picture order
Deleted cache, restarted DW and still same problem
What order did you install the extension in?
Make sure that Data Bridge is the last extension installed.
Try uninstalling Data Bridge, then installing it again.
