Coupon Discount
I have been through the Coupon tutorial and added a form and field button etc for PromoCode
What is the trigger to give a fixed rate discount
eg mat2.50 = £2.50 discount
mat5.00 = £5.00 discount
from cart total please
set the calculation to flat rate, and enter the amount of the discount.
I have set up as per grab and it seems to be going mad
I add Mat2.50 which dshould discount by £2.50 and yet it does £40.00
I have disabled all 7 discount codes
Is the grab what I should have set up ?
that looks correct.
to help troubleshoot, create a new page with a cart display on it, on the third step of the display manager interface, set it to show the discounts individually, this will help you see which discounts are being applied.
I deleted and reinstated the rules and all appears fine now
Thanks for your help
