single & multiple record insert to parent/child tables
Thread begun 7/13/2012 12:45 am by CraigR | Last modified 7/14/2012 8:58 am by CraigR | 8081 views | 4 replies |
CraigRBeta Tester
Here’s my scenario, which must be fairly common...
I am creating a site with member access only, where members can have several contact email addresses.
So I added tables members (parent) and memberscontact (child) to my database, child table to store members email address, with fields, MembercontactID, MemberID (FK to members table) and EmailAddress.
What I want to do is add a single record insert behavior for all of the fields for the members table, and a multiple record insert behavior for the email details, using the same memberid as inserted into the members table. (memberID in member table is PK, auto increment).
When I have done something like this before, I always used a lookup query to check the maximum ID of the members (parent) table and inserted the next incremental value into my child table.
With Dataassist 2, I would create a single insert record behaviour first, then code the multi insert behavior according to the solution recipe.
My question is 2 fold.
1. what is the best approach for inserting child records by this method, I feel the lookup query method isn’t the best way. (eg i think ecart uses mysql_insert_id ?) and
2. do i need to lock tables / use transactions to ensure data integrity ?
The data assist insert record behavior will store the ID of the record that is created in a session variable.
Is the session variable for the FK column value in the multiple record behavior.
Looking the table shouldn't be needed.
CraigRBeta Tester
thanks Jason.
Never really noticed that before, could have saved me some time !
Is it documented anywhere ? It ought to be
in the data assist help:
index.htm
Features -> Manage Single record -> Insert record
see the section that talks about the Session Variable section of the interface
CraigRBeta Tester
Yep. its there, but didn't register.
Maybe mentioning the benefit to storing data in related tables would help ?
