Extensions have disappeared in DreamWeaver CS5.5
Thread begun 7/12/2012 3:56 am by steve.potts360277 | Last modified 7/12/2012 10:47 am by Jason Byrnes | 3155 views | 1 replies |
steve.potts360277
Can anyone tell me how to prevent almost all of my WebAssist extensions from mysteriously disappearing in DreamWeaver CS5.5?
There doesn't appear to be a pattern to the problem. I have re-installed some or all of them (based on the amount of time it takes to do all the re-installs and depending on what I need for the projects I'm currently working), numerous times now.
After re-installing they'll hang around for an indeterminate period of time but then, like today when I really needed some of them, they're almost all missing, so I'm going to have to go through the time-intensive task of re-installing all the ones I need for today's project!
The extensions aren't just missing from DreamWeaver, they've also removed themselves from Extension Manager.
This is a real pain as the likes of Surveyor was configured to run at certain intervals to issue reminders for a number of projects - but it's vanished, and I don't know when it decided to vanish itself, so I now have to backtrack through my records to manually resubmit the sitemaps for those sites that were missed - more development time wasted!!
This is not an issue I have encountered before.
ddb6081332379
Extension for Paypal keep disappearing and cannot reinstall
This use to work so well and now I cannot get it to work at all.
Usually the extensions disappearing happens after installing a DW update. most times, the DW Update will overwrite the menu XML file causing the extensions menu access points to be removed.
open the extension manager (Commands -> Manager Extensions) to re enable them.
