Upgrade docs?
Thread begun 7/11/2012 3:05 pm by Brad Lawryk | Last modified 7/16/2012 10:28 am by Jason Byrnes | 3420 views | 5 replies |
Brad Lawryk
Upgrade docs?
Hi guys,
Is there anything special that has to be done to use the Data Assist in the DAta Bridge set?
Every input or edit form that I edited that had the old data Assist now throws errors and doesn't work.
Fatal error: Cannot redeclare WA_AB_getLoopedFieldName() (previously declared in C:\wamp\www\pges\webassist\database_management\wa_appbuilder_php.php:23) in C:\wamp\www\pges\WA_DataAssist\WA_AppBuilder_PHP.php on line 20
Brad Lawryk
And if I comment out the line as in another thread I get:
Notice: Undefined variable: WA_AB_Split in /Applications/MAMP/htdocs/pges/_pages/employers/profile.php on line 176
Notice: Undefined variable: WA_AB_Split in /Applications/MAMP/htdocs/pges/_pages/employers/profile.php on line 180
Warning: explode() [function.explode]: Empty delimiter in /Applications/MAMP/htdocs/pges/_pages/employers/profile.php on line 180
Notice: Undefined variable: WA_AB_Split in /Applications/MAMP/htdocs/pges/_pages/employers/profile.php on line 187
Warning: explode() [function.explode]: Empty delimiter in /Applications/MAMP/htdocs/pges/_pages/employers/profile.php on line 187
Fatal error: Call to undefined function WA_AB_generateInsertParams() in /Applications/MAMP/htdocs/pges/_pages/employers/profile.php on line 194
soundslike it is leaving the require once line to include the old data Assist helper file:
remove the require once line that references:
and leave the one for the webassist\database_management\wa_appbuilder_php.php file, it sounds like you are commenting out the new one:
Brad Lawryk
If I leave the line in that you suggest I get:
Fatal error: Cannot redeclare wa_ab_getloopedfieldname() in /Applications/MAMP/htdocs/pges/WA_DataAssist/WA_AppBuilder_PHP.php on line 12
The line you suggest to remove is not there.
Brad Lawryk
Got it ... I had other form pages included that still had the other code.
Glad to hear you found the problem.
