images not showing
Thread begun 7/10/2012 7:31 am by JamieEff | Last modified 7/20/2012 3:13 am by JamieEff | 3209 views | 7 replies |
JamieEff
images not showing
Hi guys
Just wondering what path may be wrong to get the attached ?
The preview works absolutley fine, but the live version the thumbnails are not visible (nor are the main images when you click on the thumbnail)
in the functions.php file I have added
$GLOBALS['absLink'] = str_replace("/WA_Globals", "/gallery",$GLOBALS['absLink']);
as the gallery is in the folder /gallery and have used this system/format for multiple powergallery installations.
The on page code is:
$pg_id
'4';
$pg_theme 'Mini Gallery';
include(
'/home/thevikkv/public_html/gallery/galleries/grid_lightbox/index.php');
Cheers
Jamie
JamieEff
Just looking at the source for the page and noticed this in the thumbnail section:
//gallery/images/barn/cache//gallery/images/barn/proportion/01_w721_h481/01_0629031138000000.jpg
I am guessing that that is whats causing my issue? but am not sure how to correct it?
Rune Brynestad
Did you find a fix for this?
I have the same problem.
Regards
Rune
Rune Brynestad
URL to my gallery: index.php?gallery=1&theme=light
URL to my page that is not working:
prosjekter.php
Code embedded in page:
$pg_id = '1';
$pg_theme = 'light';
include('/home/4/y/ybano/www/gallery/galleries/grid_lightbox/index.php');
JamieEff
this was the reply from Ray
  This was caused by a conflict with an older version of PowerCMS being used on the page.
I corrected the issue by updating the file: WA_CMS/library.php to the latest version.
I have attached the library.php file for you in case that helps your issue as well - would obviously recommend backing up original files before using any new ones.
Hope this helps
Jamie
Rune Brynestad
Hi Jamie
Thanks a lot for helping me on this. Your solution works for me too.
But I find it a bit strange since my site is built with the site sculptor tool in Design Extender, and I'm using the latest version 1.0.9.
Regards
Rune
JamieEff
I know what you mean as I am using the latest versions as well and not sure how this happened... i was waiting to do a new one to see if it happens again....
Really glad it got it working for you Rune :D
