Email Reminder issues
Thread begun 7/09/2012 2:38 am by Paul | Last modified 7/12/2012 6:51 am by Jason Byrnes | 3079 views | 8 replies |
PaulBeta Tester
Using CS5.5 and SA 205
I have created an email reminder page (attached)
I've noticed that the Email Password wizard (in SA) adds the variables "UserEmail", "UserName" to the line
"selectColumns" => array("hofName", "UserEmail", "UserName", "hoUserId","hoPswd"),
I didnt add these during the wizard steps.
If I leave them in the process errors and the text "Unknown column 'UserEmail' in 'field list'" is shown. No email is sent.
IF i remove the variables "UserEmail", "UserName" from this line, the following error occurs
html:
Warning: Missing argument 6 for WA_SecurityAssist_Definition(), called in /home/house345/public_html/hf1/pwReminder.php on line 5 and defined in /home/house345/public_html/hf1/webassist/security_assist/mail_php.php on line 34
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /public_html/hf1/webassist/security_assist/mail_php.php:34) in public_html/hf1/webassist/security_assist/mail_php.php on line 239
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /public_html/hf1/webassist/security_assist/mail_php.php:34) in /public_html/hf1/webassist/security_assist/mail_php.php on line 239
Warning: Cannot modify header information - headers already sent by (output started at /public_html/hf1/webassist/security_assist/mail_php.php:34) in /public_html/hf1/webassist/security_assist/helper_php.php on line 133
Also,
The code these errors point to is pretty much meaningless to me i'm afraid!
Any Ideas?
Thanks, Paul
The first issue occurs if you select to use one of the application presets, but use your own database table rather than letting security assist create it for.
if you select to use your own database table, you will need to go to the manage pages tab and edit each of the pages to be created to use the columns in your table.
For the second error, double click the email password server behavior and make sure a Character set is selected on the email settings tab.
PaulBeta Tester
I don't have a Manage Pages tab after opening the SecurityAssist Email Password server behaviour.
Are you assuming i used the 'Create Security Pages' application?
For this I used from the toolbar: WebAssist > SecurityAssist > Email Password
Ian S
Hi Paul,
Oddly, I had this exact same problem this evening.
This was without the use of the Wizard, simply applying the behaviour to the page. I also cannot go back in and edit the behaviour as a javascript error occurs, and when you try to delete the behaviour it deletes it from the behaviours list but leaves all but the include code on the page.
As the project i am working on is time sensitive I developed a quick workaround using UE and a recordset lookup so will document the error in more detail later on unless someone beats me to it.
All this on Mac with CS6.
Cheers
Ian
PaulBeta Tester
Thanks for your response Ian,
Hmmm, for me, this reinforces an early comment of mine regarding the limitations of these latest wizards.
I was explaining that I didn't always want to inherit/utilise all the functionality and formatting the wizards create, instead just using the updated server behaviours ad-hoc, such as the Email Password feature.
My comment got kicked into the long grass unfortunately, now here we are again with an issue relating to the same situation.
I'm hoping WA can offer a solution as the this feature is unusable if utilised in this way.
Ian S
Sure, I agree.
I have never taken the Wizard approach as I find that building my own pages and using the behaviours provides a much more flexible development environment, but I can see where the wizards might be useful for people who aren't familiar with creating web pages etc.
I have to say that since the fix to the MAC CS6 issues the latest extensions do seem quite stable and this is the first error I have come across after building quite a comprehensive CMS and eCommerce solution.
Cheers
Ian
Paul, it wasn't clear from your initial report that you where not using the wizard, in the absence of information to the contrary, i did assume that you used the wizard, as that is the way 90% of the people create security assist pages.
When applying the Email Password Behavior, did you go to the Email Settings tab to set the body of the email? you will need to set the email message to use the columns from your user table, the default email message will use the default user table column names.
also, on the email server settings tab, you will need to select a character set.
I have logged a bug in regards to the error on reinspecting the behavior.
PaulBeta Tester
Yes I set the email body using my own table
I've set the UTF-8 character set.
