Will Dynamic connections help solve my problem
Thread begun 7/05/2012 5:52 pm by phil107723 | Last modified 7/09/2012 1:28 pm by phil107723 | 7859 views | 2 replies |
phil107723
I keep getting this error message:
Warning: mysql_pconnect(): MySQL server has gone away in C:\HostingSpaces\TRICKSTAR\ericksenhonda.co.nz\wwwroot\connections\dbConn.php on line 9
And I was wanting to know would using Dynamic connections help improve the connection used by DW.
# FileName="Connection_php_mysql.htm"
# Type="MYSQL"
# HTTP="true"
$hostname_dbConn = "mysql_server";
$database_dbConn = "database_name;
$username_dbConn = "username";
$password_dbConn = "password";
$dbConn = mysql_pconnect($hostname_dbConn, $username_dbConn, $password_dbConn) or trigger_error(mysql_error(),E_USER_ERROR);
Dynamic connections probably wont help with this issue.
By default, Dreamweaver MySQL Connections (And Dynamic Coneections) use mysql_pconnect() to create the connection, this is a Persistant connection. On some servers that only allow a certain number of connections at a time, this can cause the issue you are running into. The fix for this is to use a non persistent connection by changing the mysql_pconnect() function call to mysql_connect()
change this line:
$dbConn = mysql_connect($hostname_dbConn, $username_dbConn, $password_dbConn) or trigger_error(mysql_error(),E_USER_ERROR);
phil107723
Thanks Jason I'll give it a try.
adamuabu445910
It still wont connect
change this line:
I have same problem here. I removed the (p) in pconnect and I still get the same error
Warning: mysql_connect() [function.mysql-connect]: Access denied for user 'admins'@'localhost' (using password: YES) in /home/sheieorg/public_html/Connections/sya.php on line 9
Fatal error: Access denied for user 'admins'@'localhost' (using password: YES) in /home/sheieorg/public_html/Connections/sya.php on line 9
the error message means that either the User Name or password being used in your connection are not correct.
double check that you have the correct username and password in the connection for accessing the SQL server.
adamuabu445910
Thanks Jason
I was able to get rid of that error fixing the username and password, but I now get a new error at the top of my website's content:
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /home/sheieorg/public_html/Connections/sya.php:11) in /home/sheieorg/public_html/index.php on line 37
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/sheieorg/public_html/Connections/sya.php:11) in /home/sheieorg/public_html/index.php on line 37
I really need help with this, thanks.
the error means that there is output on the Connections/sya.php file outside of the php tags.
it is reporting the problem at line 11.
look for a blank space after the closing php tag ?> or a blank line.
see this thread for details:
showthread.php?t=19285
adamuabu445910
Thanks, the error is off, still..
Thanks a million Jason, on checking I discovered I had 2 PHP closing tags. I am new to dynamic websites, have uploaded all the files using cpanel, but on login in, I now get "no database selected" please how do I connect my database. it works perfect locally.
<?php require_once('Connections/sya.php'); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
// *** Validate request to login to this site.
if (!isset($_SESSION)) {
session_start();
$loginFormAction = $_SERVER['PHP_SELF'];
if (isset($_GET['accesscheck'])) {
$_SESSION['PrevUrl'] = $_GET['accesscheck'];
if (isset($_POST['username:'])) {
$loginUsername=$_POST['username:'];
$password=$_POST['Password:'];
$MM_fldUserAuthorization = "";
$MM_redirectLoginSuccess = "trainingindex.php";
$MM_redirectLoginFailed = "index.php";
$MM_redirecttoReferrer = true;
mysql_select_db($database_sya, $sya);
$LoginRS__query=sprintf("SELECT username, password FROM users WHERE username=%s AND password=%s",
GetSQLValueString($loginUsername, "text"), GetSQLValueString($password, "text"));
$LoginRS = mysql_query($LoginRS__query, $sya) or die(mysql_error());
$loginFoundUser = mysql_num_rows($LoginRS);
if ($loginFoundUser) {
$loginStrGroup = "";
if (PHP_VERSION >= 5.1) {session_regenerate_id(true);} else {session_regenerate_id();}
//declare two session variables and assign them
$_SESSION['MM_Username'] = $loginUsername;
$_SESSION['MM_UserGroup'] = $loginStrGroup;
if (isset($_SESSION['PrevUrl']) && true) {
$MM_redirectLoginSuccess = $_SESSION['PrevUrl'];
header("Location: " . $MM_redirectLoginSuccess );
else {
header("Location: ". $MM_redirectLoginFailed );
adamuabu445910
Realy need help with this
On login in, I get a "no database selected" error. below is the code:
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
session_start();
else {
The no database selected error suggests a problem with the MySQL Login credentials,
make sure you have the correct server name, username, password and database name in the connection file.
