Dynamic Plugin not working
Thread begun 7/05/2012 9:08 am by info4753 | Last modified 7/06/2012 3:17 am by info4753 | 1923 views | 3 replies |
info4753
After adding a dynamic plug-in the page stays white.
Dreamweaver is pointing to the follwing code that seems to be wrong:
if(true){
// WebAssist Framework Builder Dynamic Plug-in: $WA_news_insert_1341504266764
switch(isset($_GET["myparameter"])?$_GET["myparameter"]:""){
case "myinsert":
$WA_news_insert_1341504266764 = new WA_Include("news_insert.php");
break;
default:
break;
if(isset($WA_news_insert_1341504266764)){
require($WA_news_insert_1341504266764->BaseName);
$WA_news_insert_1341504266764->Initialize(true);
// End: WebAssist Framework Builder Dynamic Plug-in: $WA_news_insert_1341504266764
a blank page means that a php error is occurring but error reporting is turned off.
to turn error reporting on, add the following code at line 1:
error_reporting
(E_ALL);
once we know what the error is, we will be able to troubleshoot the cause.
info4753
After copying the code, the page worked. Looks like there is a cashing problem?
But if I now click on the server behaviour, I have to add the Design Extender Activation code each time and I can't use the behaviour any more...
info4753
After deleting the cache, reentering Activation code and reapplying the plug-in, it looks like it working. Thank for you help Jason.
