Validation tooltips error on cssform builders
Thread begun 7/04/2012 3:14 pm by Miguel | Last modified 7/26/2012 10:22 am by Jason Byrnes | 3801 views | 8 replies |
Miguel
Hello again, sad to report another problem, i created a form using css form builder, then i apply to it the spry validations tooltips, it works at half if i dont submit the form they work but if i submit the form they desapear and give the normal server side error msgs, in firefox i get the following javascript error
Timestamp: 04/07/2012 05:35:43 p.m.
Error: e is not defined
Source File: validation_tooltips.js
Line: 254
that line is
var childNodes = nestedSpan.childNodes;
i apply the tooltips to several forms and its happening on each one of them, from forms created by security assist and css form builder, it does not happen on forms created directly from the data assist wizard
please send a link where i can see the problem in the browser to investigate the cause.
Miguel
I have it locally but i just opened a test server so you can check
test.php
I am not able to reproduce the problem, I am not seeing any error messages in the fire fox error console when testing your form.
Miguel
Submit it and you will see it works until you submit it, the bubbles from the spray validation tooltips desapear and then it shows the regular server side validation messages instead of the bubbles, when its submitted it doesn't even stay on the form it reloads it.
Test it on several computer here and the same on every browser i tested from IE7, 8, 9, firefox, safari, and chrome.
This is happening even to forms without design made or by css form builder or security assist the weird thing is that forms made from the data asssit wizards don't present this problem
To test it dont fill the form just submit it without filling any fields
Also the froms created buy security assist show the bubbles when submitted and stays there but they cant be close after that ill upload one made with security assist as well
Miguel
Form made directly out of the oven from security assist and apply spry validation tooltip on these ones same thing works until submitted if left empty it reloads the page the bubbles stay there but they can not be close after submitting
registro_r.php
IE9 error message:
Línea: 10
Error: 'e' no está definido
I attached some screenshots 3 where it fails and 1 (0dataa.jpg) wich is a form made directly from data asssit those dont present the problem only the forms made with css form builder and security assist
Miguel
This got broke again since the new databridge 1.0.6 update, any way i kept the file that was fixed before saved just in case
and also did what ray told me to do
  It looks like there was a bug in the validation_tooltips.js file when using password validation. That was causing a client side error so that the server validation was showing instead of the spry validation.
To correct the problem I had to update line 247 from:
queue[x].validate = new Function(validateFunc);
queue[x].validate = new Function("e",validateFunc);
I'm not able to reproduce this with Design Extender 1.1.0 and Data Bridge 1.0.6 installed.
