Results page updates very slow in Dreamweaver
Thread begun 8/03/2009 2:10 pm by troyd | Last modified 11/10/2009 12:51 pm by Jimmy Wu | 7139 views | 7 replies |
troyd
I have created several other pages in DataAssist and it all works great. But for some reason, on this current project I have a results page that takes forever to work on.
It has to be something I am doing wrong or have set incorrectly because all the other pages are just fine. These were originally created as an admin section using the DA 2.0.5 wizard.
While working on the results page in Dreamweaver CS3 Mac OSX, it gives me the spinning beach-ball or just pauses. This happens every few seconds or if I click anything. I don't have to make a change. If I highlight a .div, it spins the ball, if I highlight a server behavior in the list, it spin the ball. And if I do make a change, it spins for several seconds before I have control again.
This is driving me crazy. I have looked through preferences and I do not see where I have something set incorrectly, but it has to be me.
I can open the insert.php page, or the update.php page and work very fast on them. But the result.php page takes forever. I know it's heavy with server behaviors, but I have other sites that have similar pages that do not do this.
Any thoughts?
Like you mentioned the server behaviors can sometimes cause the page to function slowly when you are editing it if there are a lot of them on the page or if they are complex queries taking place.
Do you have a template applied to the page? If so try making a copy of the page and detaching the template to see it that helps with things. You can also try making some edits with some of the panels closed, like the application or files panel and maybe the property inspector. Also having lots of Spry objects on a page can cause it to have delays when loading and editing.
Since the other DataAssist pages are not having this problem it seems like it may be something to do with the functionality on this page. Please post back with this info and if you do not get any further I will open up a ticket for you so we can look at the files and help you work this out.
troyd
Update
Ok, I finally figured out what is causing my painfully slow DA pages when editing. Though I am still puzzled as to why.
I know this is going to sound impossible but it has something to do with a stylesheet created by DA Wizard. But I have heavily altered it. And I have not yet created a new project from scratch to test it in it's original form.
What I have done is make a copy of the Results page in a CMS. It was my slowest page during editing.
I began deleting behaviors, with no improvements. I had removed all behaviors and all php code and it still spun the beach ball every time I clicked anywhere.
Finally a I started deleting styles. Once I trashed the "Traditional_Pacifica.css" link, it was like night and day. So I opened up my original Results page full of several server behaviors and tons of PHP. As always, it began to crawl. I highlighted the "Traditional_Pacifica.css" and clicked trash. BAMB!, it was once again running at full speed in edit. I tried to get the beach ball to spin and couldn't.
So now I'm puzzled. I don't have any external image links in the styles. But I will scrub through and look for something.
One note, this is only 1 of 4 stylesheets attached to this page. The others create no problems.
Thanks,
Troy
troyd
OK, this just keeps getting weirder. I found the 1 style in that stylesheet that is causing all these problems. It's the WADAHorizLine. You know the one that makes all those little dotted lines?
.WADAHorizLine {
height: 1px;
background-image: url(../images/Pacifica/Traditional_hline.gif);
background-repeat: repeat-x;
At first I thought that maybe something happened to the gif file and it was a huge files size, but no. Any thoughts?
This is for sure causing the problem for me and I can live without that style or create my own easily. But after 3 months or so, of dealing with this I would like to figure out what's going on. I'd be happy to send files to WA tech if they want to reproduce the problem.
Thanks,
TroyD
what happens if you change:
to
/*background-image: url(../images/Pacifica/Traditional_hline.gif);*/
does the page load faster or the same.
I'll start a ticket so you can send us a link.
troyd
Jason,
Yes, I commented out that line and it fixes the problem. Just that line is all it takes.
Thanks,
TroyD
I have asked for a link to see the problem in the support ticket I created.
I'm wondering if the link to the file image is broken, and the server is taking it's sweat time to timeout on retrieving it.
Jimmy Wu
We were unable to reproduce the issue on our end, but if anyone runs into the same issue, it looks like there is a workaround for it.
