Redirect on Insert
Thread begun 7/04/2012 9:22 am by dallySP | Last modified 7/05/2012 11:48 am by dallySP | 1733 views | 2 replies |
dallySP
Redirect on Insert
I'm having problems getting my page to redirect after insert with a query string. I don't know why as I've done this loads of times before but having spent the last couple of hours trying to dissect the code thought I'd ask you. I'm sure its something realy obvious. The insert page carries a query string eg. deck_Insert.php?ProjectID=1 and I want the page to go back to the project_Detail.php?ProjectID=1 page after insert. It works fine on the cancel, update page etc, but not the insert. Code is as follows:
$projectparam_rsProject = "-1";
if (isset($_GET['ProjectID'])) {
$projectparam_rsProject = (get_magic_quotes_gpc()) ? $_GET['ProjectID'] : addslashes($_GET['ProjectID']);
mysql_select_db($database_cmsconn, $cmsconn);
$query_rsProject = sprintf("SELECT * FROM project WHERE ProjectID=%s", GetSQLValueString($projectparam_rsProject, "int"));
$rsProject = mysql_query($query_rsProject, $cmsconn) or die(mysql_error());
$row_rsProject = mysql_fetch_assoc($rsProject);
$totalRows_rsProject = mysql_num_rows($rsProject);?>
// WA Application Builder Insert
if (isset($_POST["Insert_x"])) // Trigger
$WA_connection = $cmsconn;
$WA_table = "deck";
$WA_sessionName = "WADA_Insert_deck";
$WA_redirectURL = "project_Detail.php?ProjectID=".$row_rsProject['ProjectID'] ."";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_indexField = "DeckID";
$WA_fieldNamesStr = "DeckName|DeckAbbrev|DeckProjectID";
$WA_fieldValuesStr = "".((isset($_POST["DeckName"]))?$_POST["DeckName"]:"") ."" . "|" . "".((isset($_POST["DeckAbbrev"]))?$_POST["DeckAbbrev"]:"") ."" . "|" . "".((isset($_POST["DeckProjectID"]))?$_POST["DeckProjectID"]:"") ."";
$WA_columnTypesStr = "',none,''|',none,''|none,none,NULL";
$WA_connectionDB = $database_cmsconn;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
use the following code for the forms action to ensure that the query string being used to load the page is also passed when the form is submitted:
 action="<?php echo(htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)."?".$_SERVER["QUERY_STRING"]); ?>"
dallySP
That worked a treat - thank you so much
