Cannot delete an image from results page
Thread begun 7/04/2012 4:18 am by CJ | Last modified 7/06/2012 10:50 am by CJ | 1810 views | 3 replies |
CJ
I want to delete the associated image when I delete a record from the results page. This was no problem in DataAssist but I can't manage this in DataBridge (1.05). Please can you advice me? (See attached results page)
CJ.
CJ
In the update page everything works fine. I can upload another image and I can delete the old image file after the upload is succesfull. But when I delete a record in the results page, after clicking the delete button, I try to delete the associated image file after deleting the record from database. This doesn't seem to work. Can someone explain to me how I can manage that?
CJ.
The delete button passes the ID of the record to delete using a form variable:
WADADeleteRecordID
Create a new recordset that is configured to filer the ID column using the WADADeleteRecordID form variable. In the delete file server behavior, use the file name column from the new recordset that you create to delete the corresponding file for the record that is being deleted.
CJ
Thank you Jason.
That works !!
