menu displays - until adding stats tracking
Thread began 7/01/2012 2:44 am by Sweens | Last modified 7/01/2012 11:13 pm by Sweens | 724 views | 2 replies |
Sweens
Hi
I've successfully added the menu to pages, but as soon as I add the following code, the rest of the page displays properly, but the dynamic menu does not.
$con = mysql_connect("localhost","*******","*********");
if (!$con)
die('Could not connect: ' . mysql_error());
}mysql_select_db("******", $con);
mysql_query("UPDATE HomepageHits SET HomepageHits = HomepageHits +1
WHERE ClubID='$_GET[ClubID]'");
//collect information...
$browser =$_SERVER['HTTP_USER_AGENT']; // get the browser name
$ip = $_SERVER['REMOTE_ADDR']; // get the IP address
$from_page = $_SERVER['HTTP_REFERER'];// page from which visitor came
$club = $_GET['ClubID'];
// Query for getting visitor countrycode
$country_query = "SELECT COUNTRY_CODE2 FROM iptoc ".
"WHERE IP_FROM<=inet_aton('$ip') ".
"AND IP_TO>=inet_aton('$ip') ";
$country_exec = mysql_query($country_query);
$ccode_array=mysql_fetch_array($country_exec);
$country_code=$ccode_array['COUNTRY_CODE2'];
//Insert the data in the table...
$query_insert ="INSERT INTO pagestats
(browser,ip,date_visited,from_page,country,ClubID) VALUES
('$browser','$ip',now(),'$from_page','$country_code','$club')" ;
$result=mysql_query ( $query_insert);
if(!$result){
die(mysql_error());
mysql_close($con);
Any ideas on what i need to change either in the css menu file or the code above?
Many thanks
Sweens
File attached with the menu code.
clubmenuchoice.zip
gavind
erogge sandstone.
This post has been deleted.
Sweens
I have fixed the problem - just inserted the code before everything else!
