images not showing in PowerCMS edit mode
Thread begun 6/30/2012 7:37 pm by ia | Last modified 7/12/2012 8:47 am by ia | 5995 views | 11 replies |
ia
i have installed PowerCMS from Design Extender. Installed succesfully. When i tried to edit pages, in edit mode images not displayed. What do i need to check to show images on edit mode.
When i open page site shows all images fine.
thx.
You probably just need to update your images to use site root relative paths.
Since the edit mode is shown on a page in the admin_cms folder, it won't find images that use a relative path...
for instance if you have content on your home page with <img src="images/test.jpg">
in the admin folder it wouldn't find the image, because that would map to: admin_cms/images/test.jpg
However if your original image used: <img src="/images/test.jpg"> then it could display from both locations.
ia
when i add / before path no images showing on the page. so i did not help. any idea?
<img src="images/test.jpg"> ----- shows image on page but not in edit mode.
<img src="/images/test.jpg"> ------ no image showed on page and in edit mode.
what is the full url for the page where using:
shows the image on the page correctly but does not show in edit mode?
ia
i am setting up on my computer. i did not upload it yet.
regardless, i would still like to know the full url for the page, it will help me in trying to answer your question.
ia
if i type test.jpg i can see image as well as on page index.php
but i image does not show under admin_cms.
i have changed code to <img src="/images/test.jpg">. Now shows on index.php but still does not show on admin_cms.
will it help?
ia
if i change path in edit mode to /aw/images/test.jpg
it shows image on edit mode. when i reload content now it is showing image with /aw/ but not showing others originally listed as /images/test.jpg.
all images needs to include the full path in front of the image name:
/aw/images/
This is the site relative path to the images folder that will show the images correctly on any page in your site.
ia
thank you. i assume when i upload it should not be an issue.
