New error
Thread begun 6/29/2012 12:06 pm by newimage96814918 | Last modified 6/29/2012 1:14 pm by newimage96814918 | 3152 views | 6 replies |
newimage96814918
New error
I turned on error reporting in the page and I'm getting this error:
Warning: Cannot modify header information - headers already sent by (output started at /home/smwellne/public_html/barterx.net/news.php:7) in /home/smwellne/public_html/barterx.net/webassist/security_assist/helper_php.php on line 49
It's not a space problem that I can see, What it is is I have a header.php include that has a login form and behavior on it, working fine locally but when I sent up to thye server I get this error when using it.
This is what at line 49 of helper_php.php: header("Location: ".$WA_Auth_Parameter["successRedirect"]);
I will attach a sample page that calls for header.php and header.php for your review
Also my helper_php.php file
Thanks!
Tracy
the problem is that the php code on the header.php file, lines 1 - 27:
@session_start();
ini_set('display_errors',1);
error_reporting(E_ALL);
require_once('Connections/connbarter.php'); ?>
require_once( "webassist/security_assist/helper_php.php" ); ?>
if(isset($_POST["login"])){
$WA_Auth_Parameter = array(
"connection" => $connbarter,
"database" => $database_connbarter,
"tableName" => "site_user",
"columns" => explode($WA_Auth_Separator,"UserName".$WA_Auth_Separator."password"),
"columnValues" => explode($WA_Auth_Separator,"".((isset($_POST["username"]))?$_POST["username"]:"")  ."".$WA_Auth_Separator."".((isset($_POST["password"]))?$_POST["password"]:"")  .""),
"columnTypes" => explode($WA_Auth_Separator,"text".$WA_Auth_Separator."text"),
"sessionColumns" => explode($WA_Auth_Separator,"UserId".$WA_Auth_Separator."UserName".$WA_Auth_Separator."LevelAccess"),
"sessionNames" => explode($WA_Auth_Separator,"UserId".$WA_Auth_Separator."UserName".$WA_Auth_Separator."LevelAccess"),
"successRedirect" => "memberhome.php",
"failRedirect" => "failed.php",
"gotoPreviousURL" => TRUE,
"keepQueryString" => TRUE
WA_AuthenticateUser($WA_Auth_Parameter);
needs to come before the doctype tag of the page you are including it in.
newimage96814918
What do you think would be the easiest way to solve this problem? Do I got this set up wrong? Do I need to move the code out of the header page and paste it into every page of my site?
Tracy
easiest way to get around this is to create anew page, add the login form to the body and add the Authenticate user behavior to it.
then Use Framework Builder to add the login page as a plugin to your pages.
framework builder plugins will automatically add the authenticate user behavior code to the correct place in your page.
newimage96814918
is'nt it already in it's own page sinceI have it in header.php? And I don't think I have that framework builder extension, So i might have to do it more manually?
Tracy
well, it is in its own php page, but it is not a complete php page. in others words, it is missing the basic HTML tags that make a full page.
To do it more manually, create a login page that has the login form and authenticate user behavior, on it.
then copy the login form to your header page, and make the action post to the login page, this way the server behavior is not in the header file.
newimage96814918
That did the trick! Thanks Jason!
Tracy
