Calculated fields in recordset?
Thread begun 6/29/2012 2:41 am by gary.brett434358 | Last modified 7/05/2012 9:38 am by Jason Byrnes | 10025 views | 15 replies |
gary.brett434358
Good morning, not specifically a DA issue but wondered if anyone could help? DA creates my results tables perfectly, 2 columns contain numbers & currency, is there anyway using php to calculate these fields, such as adding sum values to table footer?
I did think to do this in mysql using SUM (sales_price) AS Total but the recordset is dynamic and can change as I filter the records ie;
Staff1 10 £250
Staff2 15 £300
Staff2 5 £100
Staff3 20 £400
Total 50 £1050
If I then filter it to 'staff3' I need it to update as such;
Staff3 20 £400
Total 20 £400
Kind regards
Gary
using SUM in the SQL should work even if the recordset is dynamic.
SELECT SUM(sales_price) AS Total FROM tableName WHERE columnName = "staff 3"
would return the result you are looking for.
gary.brett434358
Hi Jason thanks for your input, the filtering is not done in mysql but via master/detail links, using code below works on master recordset but not on detail pages as its simply display the total recordset sums.
Select
tblcontacts.ContactFullName As Name,
Count(tblcases.CaseID)As Cases,
Sum(tblcases.CaseCommission) As Commission
From
tblcontacts Inner Join
tblcases On tblcontacts.ContactID =
tblcases.ContactAssignedTo
Group By
UNION ALL
Select
'GRAND-TOTAL',
Count(tblcases.CaseID),
From
Not sure how I would do this now, I had started to look at php methods but have no real idea if php can even do calcs?
the master page passes an ID to the detail page using a URL variable in the link.
on the detail page, you use the URL variable to filter the recordset using a where clause.
your recordset is not working on the detail page, because you are missing the where clause that will limit the results returned to only include those related to the URL variable.
gary.brett434358
Hi Jason, that's where I was going wrong I think, the where clause was above the union query so it filtered the details correctly but not the sums. Creating a 2nd identical where under union works in phpmyadmin but it seems I cant reuse parameters in DW?
If I create an identical parameter and use that in 2nd where it errors telling me it cant find field!
Code below works
Select
ghl_portal.tblcontacts.ContactFullName As Name,
Count(ghl_portal.tblcases.CaseID)As Cases,
Sum(ghl_portal.tblcases.CaseCommission) As Commission
From
ghl_portal.tblcontacts Inner Join
ghl_portal.tblcases On tblcontacts.ContactID =
ghl_portal.tblcases.ContactAssignedTo
WHERE ghl_portal.tblcontacts.ContactFullName = 'Barry'
Group By
UNION ALL
Select
'GRAND-TOTAL',
From
ghl_portal.tblcases On ghl_portal.tblcontacts.ContactID =
But using DW Parameter twice doesn't, do you know if that's normal?
yes, you cant use the same parameter twice, you need to create a second parameter with the same settings but unique name.
gary.brett434358
Hmmm, that's what is troubling me so much, I have tried countless times to do that but it returns "MySQL Error 1054: Unknown column in 'tblreferral.RefferalID' on WHERE clause" even after ensuring both param are named differently, sql code is below
mysql_select_db($database_ghl_portal, $ghl_portal);
$query_rsDetail = sprintf("SELECT tblreferral.RefferalID, tblreferral.ReferralName, Count(tblcases.CaseID) As Cases, tblcasestatus.CaseStatusName
FROM tblcases Inner Join tblcontacts On tblcontacts.ContactID = tblcases.ContactID Inner Join tblreferral On tblreferral.RefferalID =
tblcontacts.ContactReferrelSource Inner Join tblcasestatus On tblcasestatus.CaseStatusID = tblcases.CaseStatusName
WHERE tblreferral.RefferalID=%s GROUP BY tblreferral.RefferalID, tblcasestatus.CaseStatusName
UNION All
SELECT '', 'GRAND-TOTAL', Count(tblcases.CaseID),''
FROM tblcontacts Inner Join tblcases On tblcontacts.ContactID = tblcases.ContactAssignedTo
WHERE tblreferral.RefferalID=%s",
GetSQLValueString($ParamReferralID_rsDetail, "int"),GetSQLValueString($ParamReferralID2_rsDetail, "int"));
Also tried removing the Parameter to use WHERE tblreferral.RefferalID=$_GET['ReferralID'] with no success.
the where clause is using the table tblreferral, this table is not included as part of the FROM or inner join clause.
you cant refer to a table in the where clause that is not used in the from or inner join clause of the query
the From and Inner Join portion of the query tells the database what tables you are looking at the data for.
gary.brett434358
OK, when I add the where field to the select on 2nd query it allows the page to run but returns 0 as result, could this be due to the master page not sending a variable named Param2? I cant imagine I need to create 2 variables & parameters for each master/detail?
Can I use variables instead of parameters in DW do you know? When I try this in phpmyadmin it runs fine, something like WHERE tblreferral.RefferalID=$_GET['ReferralID']
Thanks Jason..
make sure the run time value of both parameters is
$_GET['ReferralID']
