Unknown column Error
I used data assist to do a very simple search for a persons last name in a data set and when I complete the form, and hit enter, I get "Unknown column "Last" in 'field list'.....
please help!
please help!
most likely you have a column name in your table that uses spaces in the name like:
Last Name
spaces should not be used when naming the columns in your table. Instead you should use the camel case naming convention;
lastName
or use the underscore in place of spaces:
Last_Name
I recommend the camel case convention.
