access denied
Thread begun 6/27/2012 9:28 pm by strommie421212 | Last modified 6/29/2012 9:35 am by Jason Byrnes | 2209 views | 4 replies |
strommie421212
access denied
So i followed all the instructions after upgrading powergallery- and this is the message i got when i tried going to powergallery/index.php
Any idea what this is about? (see below)
Warning: mysql_pconnect() [function.mysql-pconnect]: Access denied for user 'portfoliogallery'@'184.168.46.193' (using password: YES) in /home/content/08/8781008/html/powergallery/Connections/powergallery.php on line 9
Fatal error: Access denied for user 'portfoliogallery'@'184.168.46.193' (using password: YES) in /home/content/08/8781008/html/powergallery/Connections/powergallery.php on line 9
this error means that the user name and password used in the Connections/powergallery.php file for connecting to the MySQL server is not correct.
double check the user name and password and make sure to use the correct ones for connecting to the MySQL Server.
strommie421212
where do i even put in that information- all i've done is upload the file, and when going to the installation wizard i automatically get that message
strommie421212
cannot modify header information
ok, i've moved past that part- and now here's the next problem.
after entering password, doman, database, etc, I get this message
if ($result || ($foundValue && $foundId && $foundTheme)) { $startDir = getcwd(); chdir(dirname(__FILE__)); ob_start(); include($pg_value); $galleryHTML = ob_get_clean(); chdir($startDir); } $retVal = str_replace($theTag,$galleryHTML,$retVal); } return $retVal; } } if (!function_exists('wa_replace_once') ) { function wa_replace_once($search, $replace, $subject) { $firstChar = strpos($subject, $search); if($firstChar !== false) { $beforeStr = substr($subject,0,$firstChar); $afterStr = substr($subject, $firstChar + strlen($search)); return $beforeStr.$replace.$afterStr; } else { return $subject; } } } ?>
Warning: mysql_num_rows(): supplied argument is not a valid MySQL result resource in /home/content/08/8781008/html/powergallery/install_gallery/database.php on line 180
Warning: Cannot modify header information - headers already sent by (output started at /home/content/08/8781008/html/powergallery/webassist/framework/library.php:130) in /home/content/08/8781008/html/powergallery/install_gallery/database.php on line 183
in the database php, the code on lines 180-183 read as follows
//gallery info
$_SESSION['gallery'] = mysql_num_rows($result_gallery) >= 1 ? mysql_fetch_assoc($result_gallery) : false;
$_SESSION[$installPageID] = true;
header('Location: '.$nextInstallPage);
exit();
You started another thread for a similar problem, i started an incident for that thread to look into the problem with you, I will look into this issue at the same time.
