modifying a url?
Thread begun 6/27/2012 7:13 am by JamieEff | Last modified 6/28/2012 9:22 am by Jason Byrnes | 1771 views | 3 replies |
JamieEff
modifying a url?
Hey Jason
If I have created a 'Title' entry for a blog or news article, is there any way that I can take that entry and replace all the spacing with hyphens, make it lower case etc and add it to the end of the url that PCMS generates?
Cheers
Jamie
use strtolower to convert it to lower case, and str_replace to replace the spaces with hyphons:
<?php echo(strtolower(str_replace(" ""-",$row_recordsetName['columnName'])); ?>
JamieEff
Thanks Jason
Little confused where and what your example should be and go.
If I have the code as:
<a href="blog-article.php?zzBlogItems=<?php echo $row_BlogRS['ContentPageSetOrder']; ?>"">
include('WA_CMS/addtosite.php');
echo
str_replace(array("<p>","</p>"),"",WA_getCMSContent($database_PowerCMSConnection$PowerCMSConnection'zzBlogItems''Title'false$row_BlogRS['ContentPageSetOrder']));
?></a>
I am assuming that I change the code within the <a> tags but when I do, it just shows me an error...
Cheers
Jamie
you are asking how to modify the link, so yes, you would edit the a href tag.
I'm not entirely sure what your expected outcome is, so can't really give you much more guidance.
this code:
generates the link URL. if the BlogRS recordset returns a Title column and you are trying to add a title url variable, the code for the URL would be:
blog-article.php?zzBlogItems=<?php echo $row_BlogRS['ContentPageSetOrder']; ?>&title=<?php echo strtolower(str_replace(" ","-",$row_BlogRS['title'])); ?>
