Bug report dataasssit result page
Thread begun 6/21/2012 9:49 pm by Miguel | Last modified 7/16/2012 3:11 am by John Langer | 5445 views | 16 replies |
Miguel
Since last update im strugling to get a result page work correctly when i select that it should have a search in it, i dont know why but it does not detect the recordset, if i select on the search page creation uncheck the add to result page, the result page comes out fine but when that option is checked it creats the page full of errors.
Help please it seems still very buggy the new databridge data assist.
Also i notice that when creating pages in this new data assist now i dont have the option to not show a field.
I added the file so it can be checked i see the record there but its not detected, maby its how the code is ordered but that is how it comes from the wizard
please provide more details,
I'm not sure what you mean by:
also you say;
"it creats the page full of errors."
Please let us know what the errors are, simply stating that there are errors does not help us in determining the cause of the errors.
you also say:
"Also i notice that when creating pages in this new data assist now i dont have the option to not show a field."
In the Data Assist Create Pages wizard, select the results page, then click the pencil Icon to change the results page settings, here you can select database columns to show on the results page or remove them.
Miguel
Adding some screen shots so you can see the error or bug
about the not displaying yea i know about this
I meant that when it first came out where we select the output type there was a an option to not show no matter what
What version of Data Bridge do you have installed?
There was an update released a couple days ago to 1.0.5, make sure that is the version you are using.
Miguel
O didnt get the email of the upgrade going to upgrade and will let you know later on if it works still on 1.0.4
Miguel
it is still happening i just updated, delete the created pages and recreated them same thing with 1.0.5
What version of dream weaver is that? We can try to reproduce it and look into it more.
Miguel
Hello Ray thanks for the response with classic view selected and split code/design view
dreamweaver cs 5.5 version 11.5
John LangerBeta Tester
Was there a solution to this Jason?
I have the same problem. It didn't create the recordset so I created it by hand but the search function still does not work
Databridge 1.0.5
DW CS6
